installing a TH-400
Old Feb 1, 2004 | 07:45 PM
matts90firebird's Avatar
installing a TH-400
has anyone installed a th400 latly
if so what problems could i be facing when i take out my th350
i have the adaptor for the torque arm (even though im goin to a BMR trac pack soon)
will the driveshaft fit?
some one please leave some helpful info
thanks
Matt
Old Feb 2, 2004 | 01:09 AM
Z69's Avatar
Z69
Move the trans mount back, different drive shaft yoke, and shorter drive shaft.
Wire up the kick down switch if you want it. That's it since you already have a T350.
Why switch? You'll be slower.
Old Feb 2, 2004 | 04:59 AM
ede's Avatar
ede
don't think the torque arm adapter will work on the th400. if not good chance it could be modified or used as a pattern to make a new one.
Old Feb 2, 2004 | 06:45 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i'm using the bmr torque arm with the crossmember, if you get it you won't have to worry about that cause it removes the arm from the tranny. the rest is like they said
Old Feb 2, 2004 | 08:36 PM
im swaping to a th400 because of the engine swap im doing
im building a 383 turboed, carbed
to about 600 ponies
and my 350 cant handle that
in a nutshell
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
