How hard to convert from 4spd to a hyd 5 or 6spd
Old Feb 3, 2004 | 08:51 PM
Screamer27's Avatar
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
My dad has an 83 camaro sport coupe it has a 4cylinder with a 4spd behind it. 1983 didn't have the hydraulic setup like the later 5spds and 6spds did. How hard would it be to convert this over to a 5 or a 6 spd. The engine is in the works, 355ci with about 450hp.
Old Feb 3, 2004 | 09:23 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Not that hard. It's still a 3rd gen.
If you're serious about 450HP I'd skip the 5-speed and go right for the 6-speed T56.
You need the pedals and master/slave assembly to convert the linkage.
Old Feb 3, 2004 | 10:02 PM
Screamer27's Avatar
Engine: LS3 / L98
would the pedals work from the 4spd car?
Old Feb 4, 2004 | 06:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. The pedal assembly is different and will not work.
It's not hard at all. Piece of cake. On the other hand, brain surgery is easy for a brain surgeon, but might be a little challenge for those of us who have no brain at all.
But even without a brain, I managed to convert my 83 from linkage to hydraulics; so I'm sure that if I can manage it, anybody could.
Find a car in the boneyard, and strip it. For a T-5 conversion you'll need to find a V8 car, a 4-cyl or 6-cyl won't do; you'll need the pedal assembly, hydraulics, bell housing with fork, flywheel (which must be the one for whichever rear main seal type your 350 will be), and a few small parts like the reinforcement brackets that go between the pedal pivot bolt and the firewall, and the hardware to hold the master cyl to the firewall.
For a T-56 conversion you'll need the T-56 itself which must be 93-97 (94-97 are the better ones), its bell housing and fork, its hydraulics, and the pedal assembly either from the 94-97 car or from a hydraulic third gen. If your engine is a 2-piece rear main seal type, you'll need the $special conversion flywheel$. No stock one exists that will work.
Old Feb 4, 2004 | 07:00 AM
Screamer27's Avatar
Engine: LS3 / L98
thank you so much RB83L69. Now I have a little less reserch before I jump right in.
Old Feb 4, 2004 | 09:53 AM
You'll also need to figure out what you want to do to get your speedometer working again.
You'll need a custom crossmember for the T56 swap.
Definately use the '94-'97 F-body trans (T56). It allows you to use the stock torque arm and driveshaft. You may need to use a stock 700R4 or T5 shaft though, depending on the length of what you have now. I know the early cars are a bit different in this department.
Use the 4th gen F-car torque arm mount too.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
