custom crossmember?
Old Feb 8, 2004 | 12:30 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
custom crossmember?
my v6 700r4 crossmember will not fit into the original holes after i swapped in a 350 with a v8 700r4. can i custom make mine to fit, or will i have to go somewhere to get one??
Old Feb 8, 2004 | 01:21 PM
ede's Avatar
ede
WAG, i'd try a crossmember from a v8 car.
Old Feb 8, 2004 | 02:37 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The v6 crossmember should work just fine (it did on my conversion, the transmission ends up in the same place as with the v6)... How is it not lining up?? is it too far back or something?? The only difference between some of the v6 crossmembers and the v8 crossmember is the v6 one has a center section with extra rubber bushings... Everything lines up the same though...
Old Feb 8, 2004 | 03:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Loosen all the bolts that hold the trans to the mount, so that the mount can wiggle around a bit. Then start all the other hardware, and tighten it all back down.
It deforms itself to the stresses the car puts on it. It will re-deform once you get everything back together.
Old Feb 8, 2004 | 04:19 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
yea it is too far back now. should i drill and tap new holes in the crossmember? ill triple check to make sure it does or doesnt line up. or ill try RB83L69's way of goin at it
Old Feb 8, 2004 | 05:30 PM
ede's Avatar
ede
ok stupid question time, since it doesn't look like it can line up do you have it in backwards?
Old Feb 8, 2004 | 06:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't drill holes, don't sodomize anything. Just do what I said and it will go right in.
The kind of crossmember you have came in some V8s too. Here's the one out of my 83 HO car. Incidentally, the 2 outer slots for the trans mount, aren't stock... I put those there so I could use the early-model 2-bolt-up style mount instead of the 1-stud-down style.
You have all the right parts, just make sure they are all turned the right way, and follow the instructions.
Old Feb 9, 2004 | 01:15 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
one teeny little problem when i took the crossmember off i accidentally broke 2 bolts. wut tool do u use to take the excess bolt out?
Old Feb 9, 2004 | 01:43 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
You need to get a bolt removal kit, which can be found at most any part stores. You basiclly drill a hole in the center of the broken bolt, and the kit provides a removal tool that looks like a reemer, or a countersink which turns the bolt out.
Old Feb 9, 2004 | 06:34 PM
X86TRANSAMWS6X's Avatar
Car: 87 Conquest TSI, 86 Fiero GT
what do u do if 2 of the holes are stripped out on one side???
i didnt do it!
Old Feb 9, 2004 | 07:05 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
tap it
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
