TQ converter lock's up 1 day and stops
Old Feb 10, 2004 | 07:54 PM
NEOMASTERZ28's Avatar
Car: 85 z28
the tq conver has had a history of locking up and not locking up, for most of the time it does not lock up, but last week its was locking up fine out of no where, now this week it stopped working now when it feels like its gona lock up i get a small vibration untill i acclerate more to get out of the 1500 rpm range and it goes away, it never did this b4. tranny was rebiult june of last year and it got a reboult converter, dont know what kind, did not know about trannys too much back then.
any help thanks
Old Feb 11, 2004 | 11:29 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Sounds like electronically its trying to lock up but a pluged valve or passage wont let it.
Old Feb 13, 2004 | 11:35 AM
Car: 85 z28
update ! well im finding out that it only works a few times when the car is cold when its heats up then its seems to stop working, and the point where it does lock up i get a vibration. bad converter ?
or whats the relay or switch under by the brakes called ?
Old Feb 14, 2004 | 02:45 PM
dankhound's Avatar
Car: 91 RS
The brake switch would only cause it to not engage or not disengage. Your problem sounds different. If its temp related you might want to look towards the solenoid. Solenoids are notorious for working fine cold and failing hot.
Old Feb 14, 2004 | 03:00 PM
Car: 85 z28
where is the Solenoid located ?
1992 Trans Am
May 10, 2023 07:19 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
jklein337
Sep 19, 2018 06:23 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
