Transmission Lines
Old Feb 11, 2004 | 09:36 AM
91gta_tpi's Avatar
Car: 91 GTA
Transmission Lines
I may be buying a 1987 IROC, w/ a 350 tuned port in it, for 700.00, the person that has it is saying the only problem is the rubber transmission lines busting off because the car has too much power(torque, i guess), which even if it is something worse, I know the tuned port alone is probably worth the 700.00, so please tell me what you guys think. Thanks
Old Feb 11, 2004 | 09:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Rubber cooling lines won't "bust off" because of too much torque. Torque has nothing to do with it.
They "bust off" because they're rubber, probably just fuel line. Guaranteed to dissolve and burst, even with only the 5 psi or however little it is in those lines.
Buy the car; and go to the store and get a couple of 6' stick of 5/16" steel brake line, and make some correct ones.
Old Feb 11, 2004 | 11:27 AM
MdFormula350's Avatar
sounds like a good deal, like u said the 350 tpi engine and harness is worth the money alone.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
jer4251
Sep 1, 2015 09:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
