700r4 third and fourth blowout
Old Feb 11, 2004 | 07:27 PM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
Third gear has been slipping a small amount when I hit the gas for over a year. Last week it went all together. Reverse first and second all work fine but third pretty much just revs. Of course I cant find out about fourth since I cant get through third. Checked the archives but cant find a definitive answer to this. Is this a common problem, and if so I assume it is a transmission rather than torque converter issue right? I have the 9psi ProCharger kit ready to install.. Don't expect I'll ever put out more than 450hp with a more realistic 400. Transmission shop or is this something small that I can fix myself? (I can turn a wrench in an engine, but auto transmissions blow my mind) Comments or suggestions?
Old Feb 11, 2004 | 10:54 PM
jonarotz's Avatar
Car: 91 Z28
It sounds like you lost the 3-4 clutch. This is a common weak link in the 700r4. You are going to have to rebuild the trans. now. Sorry about you luck. Been there done that, so I feel your pain.
Old Feb 12, 2004 | 01:02 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
IF your good with tools rebuilding a trans shouldnt be too much of a strech(lots of clutchs and snap rings). The only hard part is keeping everything stacked the way it came out and getting it all in in the right order. Its not to hard to figure out if you do it wrong(clutch packs will have no play or way to much). With good notes it can be done easily.
Old Feb 17, 2004 | 09:24 AM
nebulous's Avatar
Since I'm ignorant when it comes to all but the basics of transmissions (It really comes down to the fact that its really cold outside and I'm lazy) I think I'm going to get it rebuilt at a transmission shop. My dad knows one that guarantees their work (and has replaced a tranny for him before for free), I don't know what they would have to say about the supercharger though What should I expect to pay for a rebuild?
Old Feb 17, 2004 | 10:14 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
around here, most shops charge $1500-2100
Old Feb 17, 2004 | 11:12 AM
nebulous's Avatar
Seems to me if its going to cost $1500 for a rebuild I should just buy a pro-built.
Old Mar 15, 2004 | 12:51 AM
kd5boc's Avatar
Car: 92 RS
try using the 1...2...3...OD shifter settings...this uses an overrun clutch in addition to the forward sprag and clutches to shift...or just use the chart.....
Old Mar 15, 2004 | 07:51 AM
nebulous's Avatar
If you mean just manually place it in gear, then I have tried that.. If there's some other method I'm not familiar with let me know. My tranny is on my garage floor now though, since Dana at pro-built is sending my new one this week.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
6998poncho
Sep 25, 2015 02:56 PM
