Installing a torsen
Old Feb 13, 2004 | 02:01 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Installing a torsen
I got me a zexel torsen, slp takeout posi. question is my rear is a 86, im gettin 28 spline axles, but when i change it, can i just put the 3.42 ring gear on the torsen carrier and not have to re shim it, granted i keep the shims that come out on the same side they came out of.
thanks
Kevin
Old Feb 13, 2004 | 07:35 AM
ede's Avatar
ede
check your backlash and contact pattern before you do the r&r then swap the ring gear to the new carrier and replicate the original back lash and contact pattern. not hard to do and no need to mess with the pinion, only shims you'll see will be o nthe carrier and they won't change.
Old Feb 13, 2004 | 09:08 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I just started w/ the stock .035" Pinion shim and that is the one I needed when I did the swap to the 3.42s. I had to play w/ the shims for moving the carrier side to side, but that wasn't that hard. Depending on the housing and carrier it may not just be a "use exactly what was w/ the old setup" type deal. But it shouldn't require that much work I wouldn't think.
Old Feb 13, 2004 | 01:37 PM
ede's Avatar
ede
you don't need to touch the pinion or any shims for the pinion to change the carreir. i think chris didn't read what you're doing, or understand it
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
gixxer92
Sep 1, 2015 04:32 PM
