"New" Tranny, Won't shift out of 2nd
Old Feb 15, 2004 | 08:49 PM
Ovrclck350's Avatar
"New" Tranny, Won't shift out of 1st
Here's my situation....transmission went out a week ago, so I installed a used one a friend gave me, but I can't get it to shift into 2nd, 3rd, or OD.....we think MAYBE there's some trash blocking a valve body or somtehing, so we're going to drop the pan and check it out.....
The one I put in worked fine when it was taken out of a 91 GTA. I took the pan off, installed a shift kit (triple checking every step throughout the way, so it's not installed wrong), cleaned up the valve body, reinstalled, new filter, and used B&M trickshift.
I have P, I have R, I have N, and I have OD/D/2/1, BUT it won't shift out of 1st into any other gear. The TV cable is adjusted properly, although I also pulled it out to check if that might be the problem....it wasn't. Trans fluid is full.
I used a new TC, so it's definatly good. However, I suspect that my old TC went out, and the old transmission MIGHT actually be OK.
The old one has R, and never slipped or anything, so I'm thinking that the TC just F*ed up, but I didn't want to install it and it be messed up.
I did a search, and the only thing I can think of is the governor. Could the problem with the "new" one be the governor? Which side is it on, the drivers side, or the passenger, and how does it come off?
Thanks in advance for any help.
Old Feb 16, 2004 | 10:54 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Definatly sounds like a govener problem. Like its plugged or something. Im pretty sure you have to drop the pan to get at it. It should be near the tailshaft housing.
Old Feb 16, 2004 | 08:38 PM
Ovrclck350's Avatar
OK, I checked the governor, it was fine. I also unhooked the TV cable (tranny shop told me to) and it shifted. I hooked it back up, readjusted it (same way the 3X before) and it still shifted.
HOWEVER, it stopped shifting later. Seems like once the fluid gets warm, it doesn't want to shift.
Also, the TC doesn't seem to have that high of a stall, until the fluid gets warm, then it stalls higher, but too high. I brake stalled it just to check it, and it still wasn't spinning at 2300.
Old Feb 16, 2004 | 08:39 PM
Ovrclck350's Avatar
BTW, the TC is rated at 2075...not the stock 1600.
Old Feb 16, 2004 | 11:31 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Sounds to me like you dident install the check ***** correctly or maybe placed a different size ball in the wrong spot. A few other ones that can cause this are an improperly installed pressure regulator or booster valve and lets not forget wrong gaskets. But it really sound like a check ball.
Old Feb 17, 2004 | 11:57 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
a quick question i have 4 check ***** in the case as per trans-go shiftkit instructions and 1 check ball in the valve body... D
the instructions show 3 check ***** in the valve body though. 1 far left, 1 middle, and 1 top right made of something weird like copper i forget.
Dana said forget about the one in the middle, you dont need it you blocked off that hole when you put the plugs in the plate. the one on the left I installed. the one to the far right made of that weird material I didnt see or install at all, i cant figure out what the instructions are talking about. is it retained in the valve body already?
Old Feb 18, 2004 | 10:53 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Figured it out its a copper flash checkball and its retained in the case in these year transmission... sorry for highjacking
Old Feb 19, 2004 | 01:43 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Just incase you need to hijack the thread again.
If you were to do a search about a year back I and a couple others uploaded some pics of valve body/case check ball locations. I think I uploaded a few different years too.
Old Feb 19, 2004 | 03:31 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
That gives me an idea. Do you suppose I should upload the instructions to the trans-go shift programing kit onto my thread "Rebuilding your 700R4? Check this out!" so people can get an idea of whats involved and maybe someone who loses their instructions can have it available?
Old Feb 19, 2004 | 06:30 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Re: "New" Tranny, Won't shift out of 1st
Originally posted by Ovrclck350
BUT it won't shift out of 1st into any other gear...
So do you have 1st and 2nd or just 1st? If you only have 1st, Park, reverse, and neutral, it definately sounds like a problem with the transgo install. This situation has come up a few times. One member just needed to completely clean the valve body, including valves that wern't touched in the install. Another had the incorrect 3-2 control valve installed due to not deburring the hole good enough. Forgotten checkballs won't cause a problem but misplaced checkballs may block needed passages. Good luck.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
