Trany problem???
Old Feb 16, 2004 | 09:03 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
Trany problem???
I have a 92 RS 305 w/700r4 auto trans. My problem is that when I am driving down the highway with the cruise control at about 60 mph I will be just under 1800rpms and then after a few minunts it will suddenly jump over 1900 rpms for no apparent reason. It will do this on a flat road and I can hear the engine speed up slightly. I would just like to know if anyone knows why this is happening or if this is going to lead to problems. I don't remember it doing that before. Thanks in advance to anyone with some input.
Old Feb 17, 2004 | 07:07 PM
305LG4Cutlass's Avatar
Probably your torque converter lockup solenoid is having problems.
Old Feb 17, 2004 | 07:28 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
unstable VSS signal, or unstable TPS signal are my guesses.
Old Feb 17, 2004 | 07:59 PM
camaro05's Avatar
Car: 91 Z28
I have no clue where or what those thigs are. Will I be able to find anything out about them in my Haynes manual??? thanks
Old Feb 17, 2004 | 08:27 PM
jmd's Avatar
jmd
I dunno because Helms > Haynes
Search for Throttle position sensor or TPS & read a bunch.
It's a sensor that varies voltage and you can check it with a volts meter.
If it returns an unsteady voltage signal to the ECM, the TCC will unlock, giving the rise in RPM you're experiencing.
Old Feb 17, 2004 | 11:49 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The Haynes manual isn't that good for electrical stuff, particularly EFI sensor related issues. It will cover installation and removal, but not much in the way of troubleshooting.
I agree with jmd about the cause though. I don't believe that this is trans related. Pull the VSS and check the gears for a start. These gears are fairly brittle, and only get worse with time. It isn't uncommon for them to lose a tooth or two, which could cause exactly the kind of problem you're having.
Also check you TPS for tight spots. It should provide a nice linear change in voltage with throttle angle. If there are any jumps or spikes you could have a bad TPS. Also make sure the static setting is around .57 volts. The Haynes manual will tell you how to do this.
Old Feb 18, 2004 | 07:02 AM
camaro05's Avatar
Car: 91 Z28
All right, I will sart searching for all that stuff. Thanks Guys.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
