HELP! Extra Parts! What is THIS thing?
Old Feb 16, 2004 | 09:47 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
So i finish my transmission rebuild right? and im like looking back into the box and i see this thing..
what is it? no mention of it in the rebuild book. I also have 2 small screws leftover... uh oh.
Old Feb 16, 2004 | 10:12 PM
Bandit5's Avatar
It looks like the the thing the shifter cable attaches to to change gears.
Old Feb 16, 2004 | 10:21 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
yeah WHOOOPS here I am thinking OMG im done rebuilding this thing and theres an extra part! its just the shifter thingy.
ah, but now im worried about the extra bolts.. they look like valve body bolts.. im also missing 2 pan bolts... someone said that there are 2 extra long pan bolts and now im all confused because i dont have 2 extra long pan bolts
i hope i didnt use them by accident somwhere else inside this thing...
Old Feb 17, 2004 | 12:47 AM
bes217's Avatar
Don't worry they always put extra parts on cars so that when you are fixing it there will be some left over, its OK. My dad is an engineer and says that they put extra parts in there on purpose.
Old Feb 17, 2004 | 12:50 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
oh thats a releif... cause i just found some leftover springs and valves and stuff.. and this weird funny metal piece that springs when i wack it. sigh* oh well.
Old Feb 17, 2004 | 08:09 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I think he was kidding..
There are two slightly longer pan bolts that are used to attach the shifter cable to the drivers side of the trans on the pan.. Better look to see if you left any valve body bolts out.. Things won't work well at all if you did...
The only situation that they would include extra parts was if those parts were included to make the kit fit additional applications without needing a completely separate kit/number...
Old Feb 17, 2004 | 08:10 AM
thirdgen88's Avatar
Car: 1995 Corvette
Maybe you should post a picture of your leftover parts just to be safe...
Old Feb 17, 2004 | 10:37 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
https://www.thirdgen.org/techbb2/sho...hreadid=223899
In that thread you see the first picture of valves, those are leftover valves. I know one came OUT of the valve body, one was an extra (white spring sticking out) but the third im not sure... maybe it was from the TV valve i cant remember.
any ideas about the valves?
now about the leftover screws.. i have 4 of them, i think 2 are for the shifter linkage, 1 was for the governer cover, and one was for the TV cable hold down. so thats settled...
now I DO have some leftover seals...
I know he was kdding. so was I heh.
Im just worried since this was my first transmission assembly I wonder did i put everything together right. well, ill find out in about 20 hours, tommarow ill be putting the trans in and testing it out. any last minute suggestions? im going to run it for 300-500 miles then do a fluid change and switch to synthetic transmission fluid, do you think thats a good idea?
Old Feb 17, 2004 | 10:53 PM
thirdgen88's Avatar
Car: 1995 Corvette
Seals aren't that big of deal since they are a take old off put new on one-at-a-time kind of part... I don't know if you took apart the low-reverse piston (that needs a special tool, and that will mean you will have extra seals leftover if you didn't go that far)...
EDIT: I also posted this over there, but the middle valve in your picture is the TV valve..
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Caspar
Jun 19, 2016 11:19 PM
Bob88GTA
Aug 18, 2015 03:31 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
