700R4 Stock Cooler Question
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I have the 2.8 V6 and I notice the cooler lines go into the radiator and then out. The only thing I do not understand is there is a port that comes out of the radiator below the upper cooler line. There is a bolt in the port that plugs it. I would like to take that bolt out and put in a temperature sender for the transmission temp. Would I be correct in doing so?
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You really want to read the temp before the fluid enters the cooler. A really trick setup is to run two senders, one before, and one after and use a toggle switch to go between them.
I've got no clue what that port's for. Tranny coolers in the radiator are just a small tank that allows the heat to be exchanged into the coolant. They usually only have an in and an out. Sometimes they are just a few loops of hard line in the end tank.
Engine: 2.8L V6
Yeah I thought it would be more accurate in the tranny which I could just use one of the many test ports for the sender. Interesting idea for the senders though with the toggle switch. I guess you just set up the toggle with the two sender wires.
Exactly. I read about it in a 4X4 magazine a while back. Those guys are paranoid about their trans temps, especially the guys that tow their rockcrawler across a couple states to run trails. It's no fun being stranded out in the middle of some state you don't even know.
Engine: 2.8L V6
I found a link to a page which shows what I think best represents my radiator. This link is for a replacement radiator to my car. http://www.rockauto.com/ref/GoDan/De...tml?433919.jpg It says sensor fitting w/plug on RH tank. It's a toss up for me just seems so convenient but then again not as accurate as being in the tranny.
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
the plug at the top is for the heater hose used on the v-8 cars, if you put a sender in there it will just tell you the coolant temperature, not the tranny fluid... all the tranny cooler in the radiator is ,is a pipe that does a quick in and out loop and thats it. b&m makes a kit that installes a tranny temp gauge corectly in the tranny line .....
heres the kit ive used in the past......
http://store.summitracing.com/produc...%20temperature
I don't think he's talking about the heater hose connection. That's a big 3/4" NPT threaded hole at the top of the tank. What he mentioned was a hole between the cooler lines. The question is does it go into the trans cooler tank or just the end tank of the radiator. I would try and fish a piece of wire through the plug and the trans cooler line hole to see if it actually taps into the trans cooler tank. If it doesn't I wouldn't use it for a trans temp gauge. If it does it would be an easy place to stick a sender, albeit not totally accurate.
Engine: 2.8L V6
Thanks for the ideas but the easiest idea such as mine isn't always the best. It shouldn't be that hard if I decide to just install it in the tranny.
toronto formula
Nov 10, 2015 06:17 AM
