Dial Gauge?
Old Feb 25, 2004 | 12:55 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Dial Gauge?
i have a dial gauge but how am i suppose to use it. is there a special braket i need to hold it in place or what? if so can you point me in the direction to get one?
Old Feb 25, 2004 | 09:17 PM
92MaroRS's Avatar
someone has to know.
Old Feb 26, 2004 | 04:54 AM
ede's Avatar
ede
do you mean an indicator? what are you trying to do?
Old Feb 26, 2004 | 05:06 AM
92MaroRS's Avatar
yea indicator or what ever the hell its called. i need to set my backlash
Old Feb 26, 2004 | 05:46 AM
ede's Avatar
ede
i use the kind with the plunger in the back set it aginst the ring gear tooth, try to keep it squared up aginst the tooth. i use a mag base. sounds like you need a base. what kind of lug does it have, how is it made to attach?
Old Feb 26, 2004 | 08:21 AM
92MaroRS's Avatar
the thing that moves in and out and chages the dial has a threaded portion above it about a half inch long thats what i connects with i think.
Old Feb 26, 2004 | 08:36 AM
ede's Avatar
ede
should be an attachement lug of some type o nthe back. if not then you'd need a base with kit for attaching indicators without lugs. what kind is it? model number? if it's a cheap one might be easier to buy another with a mag base.
Old Feb 26, 2004 | 08:48 AM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Here is a pic I found to give you an idea what a magnetic base setup looks like
Old Feb 26, 2004 | 08:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
www.mcmaster.com search for "dial indicators"
http://www.use-enco.com/CGI/INLMK3?PMK0NO=126050
Old Feb 26, 2004 | 12:21 PM
92MaroRS's Avatar
its a Yuasa
300-002ST
no lug in the back.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
