New gear swap!!! Synthetic or regular gear oil???
Old Mar 4, 2004 | 03:07 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Will using synthetic gear oil hurt a new gear set? Do I need to use regular gear oil for break in?
I am putting richmond 3.73's on my stock posi unit. Will the synthetic gear oil be ok from the get go?
thanks.
Old Mar 4, 2004 | 03:16 PM
ede's Avatar
ede
follow the gear makers break in procedure, usually running the car for around 10 minutes and letting it cool off for 30 and repete 3-4 times. synthetic or dino would make no differance.
Old Mar 4, 2004 | 03:45 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Keep reading the posts under the other thread you started.
I wouldn't break in a gearset with synthetic, read why on the other thread.
Old Mar 4, 2004 | 09:01 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Personally I don't think the gears will thinks about it twice if you put non-synthetic in. When I did mine I just put in the regular dino oil in, and they have been fine ever since.
Old Mar 5, 2004 | 07:44 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I made this thread because the Question is different.
You make a good point, but I think I will use synthetic.
Old Mar 6, 2004 | 09:56 AM
True, it is a different question, but the other thread has digressed into a debate on much the same subject : )
My stance, GL5 for the first 500, then Amsoil synthetic. GM posi addative if needed. I tend to run lockers, so this usually isn't an issue for me.
InfinityShade
Aug 22, 2015 08:00 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
