Is my tranny fried
Old Mar 7, 2004 | 06:17 PM
bonz's Avatar
Car: 89 GTA
Is my tranny fried
Quit some time ago I noticed my car start to chuck when you were going about 30mph or lower in OD when you give it a little more gas but when you would keep it in 3rd it wouldnt have the problem. Then I started to notice when I step on it the rpms dont steadily go up, it likes to slowly rise in rpms and then start to rise faster. I thought my fuel filter was bad so a changed it but that did nothing. Now it is starting to chuck at around 60 it chucks when you give it a little more gas. It seems to when to skip 3rd and go straight into over drive if you dont do it manualy or hold it to the floor. When I first but the car the tranny fluid was over full and smelt burnt but I changed it shortly after. It seems to still smell burnt though. I would think if it was a problem with the fuel system or engine it would have a problem through out the rpm range not just at the spots it chugs at. This really isnt the best desription of the problem but its somewhat hard to explain. But I thought I would see if any one might know whats goin on. Also if my tranny is toast I would rather put a new one in myselve then a shop since it would save my money. So would I be able to swap out the 700r4 and put in a th350 and if so what must a change. Also will the gear ratio be the same. THANKS
1989 Trans am 305 TPI Automatic, 2.73 rear, K&N filter, underdrive pulleys, air foil, tb bypass, low restriction exhaust
Old Mar 7, 2004 | 09:28 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
hmmmm if your tranny smells chrispy then change it out. id keep the 700 for a daily driver. i kept mine and i have extensive work done to my car. i believe the turbos are the same but without OD. if you swap, youll be running at higher RPMs and i dont think itll be good for gas either. stay wit hthe 700. IMO its the best auto there is. you can try www.camarotransmissions.com or www.700r4.com for a new tranny. cheaper then a rebuilt unit in most areas. shipping will be a different story though
RedLeader289
May 28, 2019 01:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
