g-force t-5 syncronized t-5 kit
Old Mar 7, 2004 | 07:59 PM
Skyler's Avatar
g-force t-5 upgrade kit...
Has anyone ever used this kit in their t-5's? if so what 1/4 time does your car run/weight/60'. I'm trying to get a idea of what kind of power this kit is capable of.
I've also heard before that part of the problem with t-5's is that the case flexes which throws the gear contact out of alignment Is there any truth to this? Thanks for any info!
Old Mar 8, 2004 | 05:08 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Just read in some magazine today that their base kit is capable of 425lb-ft of torque and their upgraded one is good for 475lb-ft.
Old Mar 8, 2004 | 07:58 PM
TexasLT1's Avatar
Car: '92 RS
G-force website says 600 ft/lbs
Old Mar 8, 2004 | 09:24 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
ok lets just quote then
Normally the stock T-5 is rated at about 300 ft-lb of torque capacity. While this is fine for stock or lightly modified engine combinations, especially running small street tires, it isn't generally enough for most of today's high powered street/strip engine combinations, especially those running bigger, more aggressive tires. This is where the G-Force T-5 kit comes into play. Although we do not like to put torque or horsepower ratings on our products due to the vast differences in clutch, engine, chassis, tire, and mounting combinations, we can give a very rough estimate. There are simply too many variables to consider when trying to figure out how much power or torque a transmission will take in a particular application. Generally, it can be assumed that with the available upgraded mainshaft, the G-Force T-5 kit will handle roughly 600 hp or 500 ft-lb. or torque in a 3300 lb. vehicle running drag radials at the track with a moderate clutch upgrade. Obviously this is just a rough estimate regarding the power and torque handling capability, but it should give some idea as to what the G-Force T-5 kit will handle in your particular application.
500ft-lbs of torque.
You better email or call them yourself for their recommendation and I'm sure they will recommend their top kit for over 400lb-fts. but that they still use the same mainshaft in all three kits which is good for 500ft-lbs.
Old Mar 8, 2004 | 11:21 PM
TexasLT1's Avatar
Car: '92 RS
Ok so I had the numbers mixed up. Main point I was making was that their website had the numbers.
Old Mar 8, 2004 | 11:27 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Oh, I was just trying to prove that I'm better than you
Old Mar 9, 2004 | 12:03 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Just out of curiosity, how much does the kit cost? I will be putting a T-5 in my new 88 GTA project car soon, and might be interested.
Old Mar 9, 2004 | 07:06 AM
TexasLT1's Avatar
Car: '92 RS
Old Mar 9, 2004 | 07:07 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
True Bolt-in dog-ring replacement gearsets capable of handling up to 600 streetable * horsepower
Kit Prices (you build it using your transmission) 1st to 4th gear sets, includes 1st,2nd,3rd mainshaft gears, 26 spline input shaft with input drive gear (4th), complete cluster shaft with gears 1st, 2nd, 3rd, and cluster drive gear (4th), and 1st/2nd and 3rd/4th sliders, hubs and bronze shift forks for 1st/2nd and 3rd/4th
$1,550.00
Overdrive gear set (.90 when available) $360.00
Upgraded Mainshafts (not included with gear kits)
ASTM 9310 High Nickel Steel $295.00
ASTM 4340-300M Thru Hard Premium Alloy $495.00
Send us your T-5 and we'll install the kit for you (labor only) Does not include rebuilt/small parts kit $250.00
G-Force T-5 kit installed utilizing new T-5 core. These transmissions utilize factory mainshafts and overdrives unless otherwise specified by customer. $2,500.00
G-Force T-5 kit installed utilizing used T-5 core. $2,100.00
Prices Subject to change without notice
G-Force T-5 Synchronized Upgrade Kits
True Bolt-in synchronized replacement gearsets capable of handling up to 600 streetable * horsepower
Kit Prices (you build it using your transmission) 1st to 4th gear sets, includes 1st,2nd,3rd mainshaft gears, 26 spline input shaft with input drive gear (4th), complete cluster shaft with gears 1st, 2nd, 3rd, and cluster drive gear (4th) $1,000.00
G-Force T-5 kit installed utilizing new T-5 core. These transmissions utilize factory mainshafts and overdrives unless otherwise specified by customer. $2,000.00
G-Force T-5 kit installed utilizing used T-5 core. $1,600.00
G-Force Transmissions website
PurelyPMD
May 5, 2016 04:57 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
DARKmj16
Sep 9, 2015 04:07 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
