manual to auto help please.
Old Mar 7, 2004 | 11:21 PM
Terry'sToy's Avatar
I searched for a while but could not find what I was looking for.
Here is my question. I have a 92 350 TBI 5 speed truck and I want to swap in a 4L60E out of a 93 350 auto truck. The mechanical part is no problem. I just don't know what to do with the computer or wiring harness.
1. do I need to install a prom for the auto into my computer or should I just use the computer from the 93 truck?
2. I am assuming I need to add something to the wiring harness, what would that be?
Thanks very much for any help.
Old Mar 7, 2004 | 11:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will have better luck here
Old Mar 8, 2004 | 09:38 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I would think that your best bet is to add an aftermarket 4L60E controller to that tranny since your car wasn't an auto and won't have the connections. BTW why in the world are you putting an auto instead of the T-5? If you don't like your T-5, send it my way and I will find it a good home.
Old Mar 8, 2004 | 10:25 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
pretty much your only option is a aftermarket trans controller...
Old Mar 8, 2004 | 08:55 PM
Terry'sToy's Avatar
Shifty, I have been searching this site but I have not found very much. Maybe I'm not using the right search words. I find lots of guys swapping auto to manual but nobody doing the opposite.
GASGZLR, this is going in a truck and it is the crappy truck tranny. I want a nice auto with a good stall. I have one in my T/A and love it.
MrDude_1, got a trans cooler already. like I said the mechanical part is no problem. I have done lots of motor tranny swaps, just not the electrical part of the ecm.
Old Mar 8, 2004 | 09:40 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
idk if this will help but I was told I would need this when putting in an overdrive transmission.
http://store.summitracing.com/partde...72#largerimage
Old Mar 9, 2004 | 11:54 PM
Terry'sToy's Avatar
Could I just use the computer and part of the harness out of the 93? Or Can I add the auto trans part of the harness from the 93 to my truck and computer.
Thanks.
Old Mar 10, 2004 | 08:23 AM
GASGZLR's Avatar
You would have to put the wiring harness from the 93 truck. Set it up so that the 93 ECU controls everything including the engine and TBI. I believe the TBI systems didn't change til 95 but the 92 computer can't control the 93 trans, would have only been able to control a 92 700R4's lockup function not the line pressure and shift points of a 4L60E.
MrDude_1's Avatar
Car: 91 Camaro Vert
i said CONTROLER not cooler.
its like a aftermarket computer that only runs the trans.
Old Mar 10, 2004 | 09:12 AM
Terry'sToy's Avatar
TransAm12sec; thanks for the link but I think what GASGZLR is saying is correct. I don't think that would work for a 4L60E.
GASGZLR; I figured this is what I would have to do. I thought the 93 truck I was getting was a 700r4 but it is not. So I guess I will have to swap the harness and computer.
MrDude_1; Sorry about that. I can't read. GM Sells controllers, but I think I'll just chop and hack the harness.
Thanks everyone for there input.
RyanJB
May 7, 2016 06:23 PM
Zane Story
Oct 8, 2015 12:40 PM
tommy z-28
Oct 6, 2015 10:58 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
88rscamar0
Sep 23, 2015 09:08 PM
