Differential and axle replacement help needed.
Old Mar 9, 2004 | 12:20 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
See sig for car info. I think my differential is toast. I was looking into getting the one from SLP that is $99. I have been told that it is a 28 spline and my car has a 26 spline. Is this true? Is so, can I just replace the axles with 28 spline axles? Does anyone know where I can get a set of 28 spline axles? The cheapest I have found them is $196 from gmpartsdirect.
Old Mar 9, 2004 | 12:27 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I think you would be able to just swap axle shafts, but I could be wrong. I would check the local junk yards for axle shafts, theres gotta be at least one 89+ thirgen there.
Old Mar 9, 2004 | 04:59 AM
ede's Avatar
ede
89 was transition year from 26 to 28 splines. all you need to do is swap in a set of 28 spline axles to make the slp posi work for you.
Old Mar 9, 2004 | 05:54 AM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Transmission: TH700R4
When I blew out the rear end on my 89 RS (26 spline) I ended up swapping the internals from a 90 bird (28 spline) without any issues.
Old Mar 9, 2004 | 09:17 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
You may be able to find the axles at a local junkyard if you get lucky. I got mine from Hawk's, banner at the top of the page. Bruce had them to me in 3 days!!!
But yeah as long as you get the 28 spline axles you are in good shape to replace it all.
Old Mar 9, 2004 | 08:53 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I called Advance Auto Parts today and they said they could get a 28 spline axle for an 82-88 rearend. Is this possible?
Old Mar 10, 2004 | 05:10 AM
ede's Avatar
ede
yeah the axles will fit as long as the carrier is for a 28 spline axle
Old Mar 12, 2004 | 03:23 PM
halloweenz28's Avatar
i heard somewhere that the 28's are wider and dont fit without borring out the housing or something, not saying this is a fact but i also have a 26 in my 83 and would like a nice "cheap" posi replacement.
just want to make sure that it is a simple direct swap in (assuming the breaks are the same, drum)
Old Mar 12, 2004 | 04:27 PM
ede's Avatar
ede
what i just said not what you heard. there is NO differance between 26 and 28 spline exles for a thirdgen except for the spline count
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
E Rod
Aug 28, 2015 05:17 AM
z28_AJ
Aug 27, 2015 08:59 PM
red90IROCls1
Aug 25, 2015 06:56 AM
