car towed with rear wheels on the ground
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I am away at college. My car was in the shop at home. When my dad went to pick it up it wouldnt start, posted in the electronics section about that. But anyways, they called a tow truck to get it home and when they towed it they used a regulat tow truck, not a flatbed. The rear wheels were on the ground. I have a 700R4. Any chance of tranny damage? The trip wouldve been no more than a few miles at speeds no greater than 45mph. Am I just freaking out over nothing? The tranny was rebuilt close to 2 years ago.
Thanks,
Matt
Thanks,
Matt
with the rear on the ground it'll spin the trans but not circulate any oil in it. few miles i doubt would make much differance but an extended trip would fry the trans.
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
any time i need to have my car towed i always say bring a flatbed. if they bring a regular tow truck i tell them to go back and get a flat bed. this goes for any car of mine not just my camaro.
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I don't know how smart this is, but I have seen a guy tow his thirdgen on the rear wheels with his truck and one of those uhaul things for cars. The thing is, he left the car running. I figure this was to keep the tranny from frying. Would this really work?
I'd prefer my car to be towed backwards. I've had my firebird towed with the rear on the ground and the trans in neutral a few times. All were at highway speeds and for a decent amount of time (to the next city). Does that cause damage?
I almost never see flatbed tow trucks here in hawaii... in fact I doubt I've even seen one in the last few years.
1 Post
Car: 89 RS
Engine: 383 in building process
Car: 91RS
Engine: 305tbi
Yeah its probably illigle to tow a car backwards because they the front wheels will be able to turn and the car will be swinging around the road. When it smacks into a wall and is totaled you will be alot more upset then if they killed the tranny.
If you have to go a long distance with the wheels on the ground with an auto transmission, pull the driveshaft to save the tranny. I would be scared for my front ground effect on a flatbed, anyone have any bad experiances with that?
If I was ever towing my car a long distance I would just pay u-haul the extra $60 for a trailor rather than a dolley
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
nope, thats why the have steering wheels that lock, i towed my 91 rs backwards, for some reason
Car: 91RS
Engine: 305tbi
They have steering wheels that lock for anti-theft purposes I thought. I could see that lock breaking if you tow it a long distance, especially if it goes through alot of turns.
I've seen cars towed backwards without any problems. In fact, the tow driver had great control over the car when he turned around and backed it into a garage. He only had to go back and forth once because it could turn so sharply.
Maybe they just need more skill (or insurance!) than the average tow guy. Who knows?
Oh and Ace, that'd be good if you're movin' a lot of cars- but the $200+ yearly reg & safety for a truck sucks. My '79 1/2 ton chevy is $187 and the truck is only worth about $500!
Laters,
Scott
Laters,
Scott
Car: No F-Body Currently :(
Engine: none
Transmission: none
Axle/Gears: still...none...(ugh)
Just bought an 87 IROC this past weekend. Since it was an automatic, I towed it backwards on the uhaul thing over 350 miles. Not any problems. I was told to tow it backwards, or look for a new tranny when I got it home. Just my 2cents.
If you're in a pinch, and need to tow an automatic with the rear wheels on the ground, just pop off the driveshaft.
I purchased a Firebird about 6 hours away and considered towing it backwards, but then reconsidered. When the guy that owned before me had pulled the engine, he disconnected the steering gear, and did not replaced the nut that secures the shaft to the steering box. I didn't see this until I got it home, several hundred miles later. The results could have been very bad had I decided to haul it backwards. Not that this would be a problem with your own vehicle, but a project car that you're not familiar with, I would be careful.
I've seen damage in as little as 2-3 miles when towed from the front. Do not do it, not worth the damage that might happen. Tow it from the rear and lock the steering with the seat belt as stated earlier.
Gotcha'. My usual tow guy always told me "it doesn't matter" everytime I asked him to tow it backwards. He'd just say that, then say it's safer to tow it from the front.
From now on I'll demand it towed from the back.
Also, now that I think about it, some of the cars I've seen towed backwards were fwd.
Laters,
Scott
Laters,
Scott
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Never tow a car with the drive wheels on the ground regardless of whether it is in neutral or not. It tears up the differential gears.
Car: 91RS
Engine: 305tbi
Engine: 5.7L TPI
Not sure exactly why it is, but i have a friend that is a tow truck driver and he said never to tow a vehicle with the drive wheels on the ground because it damages the diff and the tranny
1 Post
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
ive seen em towed both ways. doesnt really matter anyhow. if they tow it backwards you better hope your in park.
i once pushed my car into my gurage in R when it was going forward... hope that didnt do any damage
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Car: 91RS
Engine: 305tbi
Originally posted by 88IROC350TPI
pull the driveshaft off and you'll be leaving a nice trail of trans fluid as you go down the road.
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
i pulled the driveshaft off of my 81 bronco that i had and it didn't leak while pulling it
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
when i lived in NYC i got my car impounded becasue of unpaid parking tickets ...and the MF'ers towed it by the rear wheels and litterally ground THROUGH the nose (we need a more p!ssed off smily) so with me having a 5 speed it will be either towed on a flatbed or by the front tires....
Okay I got another question for you guys.
My car is an auto, if I haven't mentioned it yet.
If I'm cruisin' downhill or someplace where I don't use the gas to keep speed, will putting it in neutral cause any problems?
I'm assuming that if my engine isn't running and I'm going downhill, it's best to put the transmission in neutral rather than drive. By the way, I don't do that last part intentionally....
Laters,
Scott
Laters,
Scott
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
Am I the only one who thought to just disconnect the drive shaft from the differential and tow it that way?
Car: '82 Z28
I had to get mine towed backwards after the stock converter split open and left all the trans fluid on the road. That was a fun day Opened up the transmission and there was maybe half a quart left lol
Car: 75 firebird..9.30@150.5
Engine: twin turbo pump gas sbc
Transmission: glide
Axle/Gears: 3.42s
when my 87 bird got stolen in akron ohio,they towed it backwards on a wheel lift from there to ontario canada, with no probs, i thought for sure they would flat bed it, i almost fell over when i saw it towed in like that. but the steering wheel lock holds fine for that, isn't really any force against it towing them that way anyway.
The only exception I could see maybe is a transaxle where diff and trans. share fluid & it's an automatic that you've left in neutral.
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Thankfully, the LS1 shaft I just got is much better than my tired old steel shaft I had to use for a while...
1992rs/ss
05-19-2020 07:02 PM
colton_carlson
03-08-2019 12:21 PM
kah992
08-19-2015 02:55 PM
