Rear is dieing? Please confirm..
Old Mar 10, 2004 | 09:16 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Ok I have my stock 2.73 non-posi rearend in my car. It has 127k on it now. Last 15k has been behind my 350. Anyways last week I decided to get rid of the tires since I have new kuhmo's at home. I power brake it expecting to get the one tire to smoke....to my suprise I go completely sideways.
Look back and two nice black marks...so I do it again.
It is spinning both rear tires. Evenly also. Buddy from work said pieces of the spider gears could be welded together making it like a locker...
He said his non-posi 12 bolt in his chevelle did this until it finally died.
What you think?
Old Mar 10, 2004 | 10:34 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
With a non posi the wheel with the least resistance will spin. If you hammer it without the brakes on one wheel will brake loose and keep spining while the other gets no power. If the right amount of braking is placed on the rear the wheel with the least resistance will switch between the two. Thats why you got the two marks.
Old Mar 10, 2004 | 10:50 AM
Transmission: 4l60e
Ok so what I experienced could be normal?
It has never did this before.
However I just replaced the back brake shoes BUT the pass side self adjuster isn't working at all so I basically have to brakes on that side. I'm getting the self adjuster and hardware kits friday when I get paid. Maybe that had something to do with it?
Old Mar 10, 2004 | 12:42 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
my 2.73 open did this. it would leave two at first then the drivers side would die out eventually and the passenger side would go for about another 20-30 ft. now i have posi so it stays even so im happy. i wouldnt worry about it.
Old Mar 10, 2004 | 02:05 PM
Transmission: 4l60e
Even if it does die I really don't care. I already have another rear-end I could throw in if I have to. In a few weeks hopefully I'll have the money to get the posi and gears in it.
Old Mar 13, 2004 | 06:01 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
my friend just got new gears installed about 2 months ago with no posi and sometimes it will leave both tire marks so i would say your gears are fine. when u start hearing noises then u have a problem
eightsixseven
Dec 16, 2024 01:50 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
EFR2000
Aug 18, 2015 08:54 PM
