305 auto tranny to manual etc
How is it going every one? I have two questions for you guys today. First being... What kind of modifacations would need to be done for an automatic 700r4 transmission into a 5 speed manual tanny conversion into 1986 Iroc z28 with a 305 HO motor. Would you have to fabricat any thing to do so or would you just have bolt up flywheel, clutch, tranny, clutch pedal, the master cylander, run all the lines for the clutch and rewire the nutral start switch? Would there be any thing else needed to do so? Ok the second question being..... How hard would it be to convert a 1986 Iroc z28 from a completely stock 305 carberatted motor with an automatic transmission to 383 stroker motor with carb and a t56 6 speed manual transmission.. What would you need to do so with that swap???? Would there be much fabrication if any???
ambainb
Apr 25, 2016 09:21 PM
2nd, 305, automatic, convert, converting, fbody, gen, irocz, manual, swapping, transmission, transmitions
