T56 slave cyl question.
Old Mar 11, 2004 | 08:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
does the below slave cyl pic look right to you? i mean, its kinda open, shouldnt there be a cover or somthing? and some kind of spacer between the slave cyl and the bellhousing?
am i missing a part, or does it really just sit like that?
i got this entire T56 setup off a donor car that was a theft recovery... one of the stranger items stolen was the clutch master/slave cyl assembly (and the shift ****)
so im not entirely positive thats right..... id expect there to atleast be a cover or somthing.... i donno.
Old Mar 11, 2004 | 08:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ok from the pic below, i see what im missing.
anyone have the part number?
im talking about the silver cover thingy that you can see between the bellhousing and clutch cyl in this pic, but not in my first pic:
Old Mar 11, 2004 | 08:49 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
nevermind, a local friend has one.. i'll post the number when i get it
Old Mar 30, 2004 | 09:04 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
did you ever get the part number for that part? I need one.
Thanks,
Kory
Old Mar 31, 2004 | 09:37 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Thanks,
Kory
no
i looked on it, and its not cast or stamped into it anywhere
Old Mar 31, 2004 | 03:52 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Call your local dealer and get the part #, shouldn't be hard. Just tell them its the mount right next to the slave cylinder, and if their stupid like they are here, just go there and flip thier monitor around and point it out to them.
Old Mar 31, 2004 | 04:47 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I need to get that spacer as well. When I bought my T56 setup, I thought I got everything, but when we put my tranny in my brothers car, he was asking about the spacer.
We just got a couple of old sockets and cut them down to size and put them there, but I do want to get the right peice when I put the tranny into my car.
Old Mar 31, 2004 | 05:20 PM
Car: 88 Iroc
Transmission: t 56
I'll try and check with the dealer friday. If I can get the part number I'll post it. In the mean time is this spacer really necessary? if so how long should the temporary spacer be made? I would like to get this done tonight.
Thanks for the replys,
Kory
Old Mar 31, 2004 | 07:39 PM
pasky's Avatar
Helps keep the dust and all other crap out.
Old Apr 11, 2004 | 07:26 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
No, it's for locating the slave the proper distance from the fork. Clutch dust is everpresent inside the bell regardless.
Old Apr 12, 2004 | 07:54 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Kory
no. its not. its possible to drive without it.
however, its not advised...... see how close the master cyl is to the bellhousing in my pic? its suppost to be a lil farther back.
you could make a spacer to work for a little while.... heh, if you were using nylock nuts and checked them often, you could even get by with no spacer.... but its best to just have the correctr part.
Old Apr 12, 2004 | 08:19 PM
Zepher's Avatar
My brother is still driving around using the 2 sockets as spacers.
no one has the part number yet?
Old Apr 13, 2004 | 09:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
heh, you can even drive without a spacer if you have nyloc nuts (or you lock the nuts someother way)
i looked alll over the part dude... there is no part number cast or stamped into it.
someone is going to have to find a good dealership and point out the piece on the computer.
Old Apr 13, 2004 | 06:28 PM
bennyhonda's Avatar
Car: 1992 Camaro RS
Here you go
Clutch Actuator Bracket - 12523315
Old Apr 14, 2004 | 09:11 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: Here you go
$20.56 from www.gmpartsdirect.com (28.51 to have it at your door)
thats not tooo bad for a dealer part... heh.
thanks for the part number.. can i ask where you found it from?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
