Possible to run a 700R4 without a governer?
Old Mar 15, 2004 | 07:48 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
If I put in a full-manual valve-body, would I still need the governer? My tranny is eating governor gears, but it shifts fine with a new gear for a few miles, so I dont think there are any major components that are messed up. Any idea what could be eating the gear up?
Old Mar 15, 2004 | 09:14 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If you have a full manuel trans i dont see why you would need a govener. If your only replacing one gear try replacing both. Eventhou it may look of if its damaged it will tear up new gears really fast.
Old Mar 15, 2004 | 09:24 AM
Scott_92RS's Avatar
Car: 1992 RS
What other gear is there to replace? Anyone else care to chime in on this?
Old Mar 15, 2004 | 09:39 AM
dankhound's Avatar
Car: 91 RS
The gear that drives it. On the output shaft.
Old Mar 15, 2004 | 10:10 AM
Scott_92RS's Avatar
Car: 1992 RS
Does the tranny have to be removed to get at that gear? Are you sure you're not talking about the VSS drive gear?
Old Mar 15, 2004 | 12:56 PM
Pro Built Automatics's Avatar
If you are eating up gears that soon, it could be that you are using a TH350 governor gear, it looks almost identical except that the pitch on the gears is slightly different, and will cause this. Another thing to check is the cover being to tight (in the middle) and pushing on the governor itself, and this will strip it. When installing the cover "do not" hit in the middle of the cover just the edges. If you have the tail section off, then you can see what clearance you have. .030" - .050" is ideal, less than that can cause problems.
Old Mar 15, 2004 | 01:32 PM
Scott_92RS's Avatar
Car: 1992 RS
I'm not sure about the gear that was in there to begin with, but I purchased a brand new governor assembly for a 700R4 and installed that, and now the transmission is exhibiting the same problems that happened the first time I lost everything but first gear. The middle of the cap was pushed in (like it was hit with a hammer) when I first removed it, but I repaired the cap (I didnt have another one handy), and re-installed it the correct way (tapped around the edges). I've been trying to decide weather or not I should attempt to repair the 700, or if I should just go ahead and get a TH350. I've got another governor gear, and a brand new cap, I'm just dreading having to fix the gear again, it was a pain in the but to put that cap back on with the tranny in the car.... Do you have any tricks for putting that cap back on while the tranny is in the car? Also, can a mal-adjusted TV cable cause the governor gear to get chewed up?
Scott
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
