rear end
Old Mar 17, 2004 | 07:32 PM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
rear end
how many bolts is the stock 92 camaro rs 305 and what is the difference between 12 and 10 bolt?
Old Mar 17, 2004 | 07:39 PM
steve8586iroc's Avatar
2 bolts
No really, the 12bolt is a lot stonger but has to be custom built to fit a thirdgen. There is also a couple of different 10bolts as well.
Steve
Old Mar 17, 2004 | 09:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
This belongs here.
Old Mar 17, 2004 | 09:36 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
the 12 bolt has a ring gear diameter of 8.875'' (pretty sure thats right) and the stock camaro rear for your model has a ring gear diameter of 7.625".... there is also another 10 bolt with an 8.5" ring gear... the 12 bolt is alot stronger than the stock camaro rear, but if your not putting much HP and TQ to the ground then it would be useless to go that big...
Old Mar 18, 2004 | 04:05 PM
ChevyCamaro420's Avatar
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
Just so that everybody who reads this post knows...
if you want to know if ur car has a 9/10/12 bolt etc., just get under your car and count the number of bolts holding on the differential cover.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
