c'mon, help a brother out.......
Old Mar 18, 2004 | 07:44 AM
crewguy's Avatar
86 Z28 w/ 305 TPI, 700R4
how do I identify the type of rear in this car? Son wants to change to a posi-carrier. I don't have a clue as what type to look for. I woulf prefer to purchase used, along with some shorter gears (3.73?). Is there a service that would allow me to find out what the spline count of the axles are? What type of carrier do i need to look for?
Thanks!
Old Mar 18, 2004 | 07:58 AM
ede's Avatar
ede
count the bolts on the cover
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
assuming it is stock....
it should be a 26spline 7.625" carrier. if you are planning on going with 3.73's you will need to get a 3series carrier.
Old Mar 18, 2004 | 08:01 AM
ede's Avatar
ede
or 3 series gears made to fit a 2 series carrier
Old Mar 18, 2004 | 08:38 AM
Dewey316's Avatar
Car: 1990 Camaro RS
or a 2series carrier, 3 series gears, and a ring gear spacer. but how did i know, someone would call me on that.
Old Mar 18, 2004 | 04:00 PM
ChevyCamaro420's Avatar
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
I also have an '86 Z28 305 TPI/700R4... There were different options, but i have a 10-bolt 7.5 inch rear, 2.73 gears w/2 series carrier non-posi, and drum brakes.
As for spline count, 89's and up have 28 spline, '88 and below have 26-spline...
You need to look for a 3 series carrier. 2 series carrier for gears 3.23 and lower (numerically lower i.e. 2.73's), anything above needs 3 series carrier.
Or you could do what ede said and get 3 series gears made to fit a 2 series carrier...
Hope that helps out a bit
Old Mar 18, 2004 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
7.5" or 7.625" doesn't much matter, the gears & carriers interchange. Most often they're referred to as 7.5". Technically, 7.5" ended in '84.
3.08 and lower is 2-series on these diffs. 3.23 and higher is 3-series. 3.23-up gears for a 2-series carrier are typically $15-25 more than 3-series carrier gears.
Some '89 and all '90-up have 28 spline axles.
Good thing this is all so straight forward...
Old Mar 21, 2004 | 02:52 PM
crewguy's Avatar
Is there a number that I call get off the rearend that I could use to identify what type of carrier and axles it uses? This rearend came off a doner car, installed by a previous owner
Old Mar 22, 2004 | 11:14 AM
ede's Avatar
ede
you need to pull the cover and look. doesn't really matte what it left the factory with, doesn't mean it's still like it was when it was shipped.
Old Mar 22, 2004 | 01:29 PM
five7kid's Avatar
There is, passenger side axle tube, stamped in, a 3 character code. Usually have to scrape off the x.x-decades of accumulated crud to see it.
The code will provide base information, but to really know you have to do what ede said.
Ed1LE
Sep 30, 2018 09:14 AM
Damon
Sep 26, 2015 04:29 PM
buckeyecelt
Sep 24, 2015 05:50 AM
Thirdgen89GTA
Sep 18, 2015 09:52 PM
Bob88GTA
Sep 10, 2015 09:07 PM
