Put trans on wrong and broke it! Need help
Old Mar 21, 2004 | 11:38 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Background info:
I just put in a new engine in my car and when I was a mounting the old transmission I must have messed something up because they didn’t fully mate and when I torque it down something popped they went together. When I later tried to turn the engine by hand to set the valve lash the engine would not budge. I used the starter and finally after many tries got the engine to finally turn with a lot of beating. Now I know from my other post (click here) that I didn’t properly line up the torque converter and the pump on the transmission and probably broke the pump.
Problem:
When I put the car in drive or any other gear nothing happens at all, it acts just like it was still in park. It seems like there is no line pressure what so ever in the trans.
Question:
I know I probably broke my pump but do you think my torque converter is okay? Roughly how much would it cost for a trans shop to fix the pump, or is it not worth it and instead I should just buy a new transmission?
Old Mar 22, 2004 | 09:49 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The pump is easy to replace. Its the last thing that goes in the trans so it shouldnt cost to much to replace. The converter may or may not be broken. Does it still spin freely with little endplay?
Jake_92RS
Jan 28, 2020 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
Leggman1
Aug 6, 2015 04:15 AM
