9-bolt issues
Old Mar 22, 2004 | 04:10 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
9-bolt issues
Guys, my car came with the 9-bolt rear end. The posi doesn't seem to be working any more. I've heard that if you drain the diff oil, refill with synthetic gear oil and do NOT add limited slip additive, the posi function will come back to some degree. Any thoughts on this?
Also, where do you ger 9-bolt parts, nobody seems to carry them. Summit, Jegs, you listening??
Old Mar 22, 2004 | 06:25 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
www.9bolt.com high dollar though!
Old Mar 22, 2004 | 07:52 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
complete install kit:
http://store.yahoo.com/ratech/79bogmax.html
gears:
http://www.ring-pinion.com/
Two of the cheaper places I have found while looking for parts. I was satisfied with both suppliers.
Edit: sounds like you need to shim your carrier too. Shims are not cheap. Larry Burd on this site sells them. The cones are wearing causing the diff not to lock both alxes. The first thing you should do is have it checked out to make sure its worth your while to fix. 9 bolts can be expensive so there is no need buying parts for something thats cheaper to replace than to rebuild.
Old Mar 22, 2004 | 07:57 PM
I actually used http://www.ring-pinion.com/ today and got the master rebiuld kit for the 10 bolt. got it for $75.00...pretty good deal if you ask me.!
Old Mar 23, 2004 | 01:08 PM
Tremo's Avatar
Thanks guys.
Old Mar 23, 2004 | 07:50 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
you'll need to shim the cones in your diff. email larry burd, he sells the shims. Look in the faq section for a post by me called "9bolt info" it will tell you how to do it.
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
