Which tranny have I got?
Old Mar 24, 2004 | 04:08 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Which 5 speed tranny is in the 91 Formula 305 TPI? I believe my RPO code is MK6? Is that the World Class on NWC? Anyone know what the gear ratios are for 1 thru 5 on this tranny? (especially 5th).
Appreciate any help you can will be appreciated!
- Vern
Old Mar 25, 2004 | 04:33 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
If it is the original T-5 then it is a WC T-5. Gears are:
2.95:1
1.95:1
1.34:1
1:1
either .59:1 or .7:1
Old Mar 25, 2004 | 04:35 PM
vernw's Avatar
Thanks for the reply, GASGZLR. Have any idea how can I tell which 5th it has?
Old Mar 25, 2004 | 04:46 PM
GASGZLR's Avatar
Yeah if there is a HUGE rpm drop (almost 1000 rpm) between 4th and 5th then you prolly have the .56.
Old Mar 25, 2004 | 08:17 PM
weberusn's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Gasgzlr,
How is your tranny holding up behind that setup that you have. I am going to have a similar setup and was just wondering?
Thanks bro
Bill
Old Mar 26, 2004 | 06:22 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
you have a WC t-5 in your car, to answer that question
Old Mar 27, 2004 | 01:12 AM
vernw's Avatar
Thanks on the WC info for my T5. Now all I gotta do is figure out what my overdrive gear is. I'm evaluating a new trans - TKO or T56 conversion most likely. My new 383 we're installing is probably going to need a stronger trans... but at least the old motor is out. Tomorrow we put in the 383 - WHOOOOPEEEE!!!
--- Vern
Old Mar 27, 2004 | 09:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put the trans in 5th, spin the input shaft 10 times, and count how many times the output shaft turns.
Don't outsmart yourself.
Old Mar 28, 2004 | 10:49 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
lol, so direct...
Old Mar 28, 2004 | 06:05 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
If it is a MK6 the 5th gear is .73 if it was M39 5th is .63. As long as it is the original trany and 5th has not been changed a MK6 5th is .73
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
