Wierd transmission problem.. Please help
Old Mar 27, 2004 | 02:39 PM
MichaelShaub's Avatar
Car: 1988 Notchback GTA
Engine: 350 L98
Transmission: 700 r4
When i drive it shifts redline at WOT..
now i threw a code 33 ( MAF sensor) and it now does a strange thing.. it drives fine. i get up to maybe 40 mph and the brake.. the rpms go way down and then with no foot on the throttle the rpms go from 1000 to 1700.. up and down up and down a couple times then its back to normal.. then accelerate again and same thing.. then at higher gears a small tap on the accelerator and the transmission jerks..
what do you think the problem is?
slipping..
MAF...
Tv cable?
also.. can the bad mass air flow sensor make my engine rev by itself???
Please help..
Old Mar 27, 2004 | 02:40 PM
Engine: 350 L98
car info
The car is an 86 trans am with the 305 TPI.. 700 R4..
195,000 miles
Old Apr 1, 2004 | 09:06 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Sounds like the TPS is going bad. I have seen this happen to other cars. I would defientely address the electrical problems. If you have a manual on the car, it shoud tell you the desired raneg of the sensor(s). Use a digital multimeter to test these.
mud runner
Nov 2, 2015 07:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
reactor60
Sep 22, 2015 01:44 PM
andy74
Sep 3, 2015 08:41 AM
