gear backlash
Old Apr 2, 2004 | 06:49 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
gear backlash
what is a good backlash setting for my rear end i have it set at .005 right now and was just wondering before i finish and add the gear oil
Old Apr 3, 2004 | 06:17 AM
ede's Avatar
ede
should of been etched on the gear set of on a packing slip. .008 is usually what i shoot for. is your pinion depth set to spec?
Old Apr 3, 2004 | 07:25 AM
Engine: LO3 and LT1
my pinion depth is actually .002 to shallow and it has no shims in it i have no idea how that happened but its the closest i could get it. the gears do not make any noise with the carrier in. but i havent checked the pattern yet so i wil see what happens when i set the pattern
Old Apr 3, 2004 | 07:36 AM
ede's Avatar
ede
with no shims i'd suspect you made a mistake somewhere along the way. most gm 7.5 ten bolts will take a .035 shim.
Old Apr 3, 2004 | 06:56 PM
Engine: LO3 and LT1
when i measured the pinion dept with no shims in it it was 2.313. the pinion depth stamped on the pinion is 2.317 i dont see why or where i would have gone wrong
Old Apr 5, 2004 | 05:22 AM
ede's Avatar
ede
guess i don't either, but still i don't think a .004 shim would be right, however if you're sure you checkd it right and all i'd stick the .004 shim in and bring it into spec.
Old Apr 5, 2004 | 03:07 PM
Engine: LO3 and LT1
i used the marking compound and it showed that the pinion was to far back so i added the .035 shim and it looks pretty good. and since i can only work on it at school for about 3 hours a day i will have to wait till tomorrow to get everything right
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
