9 bolt posi acting funny
Old Mar 22, 2004 | 09:44 PM
jdrafke's Avatar
Well, my posi has always made a bit of a whine noise since i have had it and the guys at the local shop said it had a bit of play in it but nohting that bad. A few times i have hammered my car from a stop and it felt like it was slipping. Thought it was the trans but the trans is fine at wot all the time when done from a roll. So two nights ago i go into the empty lot across the street and hammer it and what u know only one tire spun. But today i had my g/f in the car and i hammer it from a stop and the car seems to take off then slip again and the rpms kinda stayed high. I get out of the car and this is what i see: It looks like the posi was working and started to lay down 2 patches then all of a sudden the drivers side patch stops about 3 feet and i have about a 25 foot patch from the other side. Tried to search and couldnt tell if this was normal or not. Any suggestions?
Old Mar 23, 2004 | 02:14 PM
383 rocket bird's Avatar
Sounds to me like the posi is on it's way out. When the clearances get too big getween the cones this is how the posi will act until you eventually have no posi at all. The rear end will still function okay you will just not have posi. This is where mine is at right now. -John
Old Mar 23, 2004 | 02:55 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
same here, only one tire spins atm
how much does it cost to fix? when i put in my 3.73's will that fix my problem?
Old Mar 23, 2004 | 03:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Nope. The gears will not fix that. You could have worn clutches or other problems with your clutch that are causing the one wheel peel.
Old Mar 23, 2004 | 04:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
clutch in the rear?
Old Mar 23, 2004 | 06:12 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
clutch in the rear?
Yup. Some posi carriers have what are called clutch packs. Someone else who is more skilled in this area can give a better deffinition of them. But anyhow, they can wear out just like a tranny clutch.
Old Mar 23, 2004 | 06:57 PM
jdrafke's Avatar
hmmm. you guys think this is y my rpms are shooting up sumtimes when i hammer it at wot from a stop? COuld my 2600 with a stall with 2.77 in the back cause me to spin even into second without getting traction? I know the gears in the rear suck but im just hoping my tranny isnt slipping. it doesnt/has never slipped when hammering it from a roll so im suspecting the rear.
Old Mar 23, 2004 | 07:46 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
9 bolt rears use cone type differential. There is no clutches, those are in auburn type differentials. You'll need to shim the cones to bring it back like new. email larry burd, he sells the shims. Look for my 9bolt info post in the faq section for info on how to do it, or any other bit of info you'd ever want to know about a 9bolt rear.
ta ta
Old Apr 5, 2004 | 03:32 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
How involving is this? I have the axles out of my 9 bolt right now and im in the process of painting it and swaping to PBR brakes, Im guess I would need to totally remove the carrier?
Will
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
