Replacing bearings on 9 bolt axle
Old Apr 5, 2004 | 02:49 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
How should I go about this? Anyone have good luck with a particular brand of bearing? I have the axles out and figured I might as well have em serviced while they are out. Thanks fellas
Will
Old Apr 5, 2004 | 05:26 PM
ede's Avatar
ede
if you already have the axle out all you need to do is r&r the bearing. press or torch works to remove them. press to install.
Old Apr 7, 2004 | 01:07 PM
Steve89GTA's Avatar
ya, from what I remember...you don't have to even take the cover off with the 9 bolts. I had all of the bearings changed after my pinion seal blew and I asked about the wheel bearings...the guys said they're easy to change on 9 bolts and you don't have to take the center section apart or even take the cover off.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
rsrmoore
Aug 7, 2015 08:44 PM
