Tranny?
Old Apr 10, 2004 | 07:43 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Tranny?
I have a 1988 Firebird 2.8 5 speed. I am getting a whining noise out of the tranny when coming to a FAST stop. When i push the clutch down then one second later the brake, i here a whining noise while the car is running and when it comes to a stop it stops. It only does then when i come to a sudden stop and does not happen when i come to a normal stop. Any ideas? I was thinking old tranny fluid or maybe low. But put in new fluid. i have no clue. My car is off the road and only gets driven short distances is. Could this have something to do wiht it, I dive it everyday though. But not enough to get it out fo second gear.
Old Apr 10, 2004 | 10:16 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Probably a worn throw out bearing. If your trans was whining you would here it while driving.
Old Apr 10, 2004 | 10:34 PM
Engine: 2.8 Lt
Transmission: 5 Spd
No it is quiet while driving. Only when coming to a stop. Any other ideas or could it still be that?
Old Apr 11, 2004 | 12:27 PM
TA5LiterHO's Avatar
Well, if it only does it when you push the clutch in to stop then pull it out of gear, it is most likely the throwout bearing. Since it doesn't whine in gear your trans itself is probably good.
Old Apr 11, 2004 | 02:08 PM
Engine: 2.8 Lt
Transmission: 5 Spd
how do you go about replacing or checking that? Any ideas there. Even when i come to a stop in first gear clutch is down and brack is on, it continues making that noise. Could the clutch have air in the lines? Thanks again
Old Apr 11, 2004 | 09:44 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Did a little more testing. Found out when i push the clutch in, the noise is NEVER there, when i step on the brake it shows up. Still the throw out bearing, (does not always make that noise). Also sometimes continues to make the noise even when the car comes to a complete stop and you can sit there and it just continues to make that noise until it you push it out of gear or you left up on the clutch, move and little then stop. Could I have air in my clutch lines? Any ideas guys?
Old Apr 13, 2004 | 06:35 AM
Engine: 2.8 Lt
Transmission: 5 Spd
Nothing guys? your killing me here
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
