T-56 Problems
Old Apr 14, 2004 | 11:15 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
T-56 Problems
Ok, I have a 95 T-56 (bought it 3 months ago) and I didnt replace the clutch and when i inspected it looked good, but I was unfamilar with the t56 and I noticed the throw out bearing was kinda hanging on the tranny, I didnt know there is a rod to hold it so i put fork on and tested, seemed ok.
Now I just test drived the car, when I put the clutch all the way down I hear a rwwwrwwwwrwwww, like the throw out bearing is touching the PP pretty bad.
My shifter also doesnt jump to the 3-4 position when i take it out first and put it in neutral, its a brand new t-56 PRO 5.0. The previous stock shifter did the same thing.
Now my last problem is I can't shift into 2nd, it will pop out and if I hold it in it will grind second gear. I can go in 3rd and 1st just fine but its real high thanks to the throw out bearing being goofed.
The master and slave cylinders are leaking fluid, already ordered a new one from gmparts. Anyone have any ideas on this one? I just pulled the tranny out and while its out is there anything I should check or could this problem be from bad hydraulics + throw out bearing
Old Apr 14, 2004 | 02:13 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Sounds like the 2nd gear syncro may be going if will grind going in, and then pops out some...
Old Apr 14, 2004 | 03:37 PM
pasky's Avatar
How hard is this to replace or even check, anyway I can pickup a syncro? Please don't say "Go to a transmission shop" if I wanted to do that I wouldn't be asking on here`
Old Apr 15, 2004 | 01:52 PM
pasky's Avatar
Found the problem with second, i took the fork plate out and saw that the 5.0 stop screws weren't letting it into second enough (I did it the way they said, put it in gear and tighten the screw, back oout a full turn and tighten) but guess it wasn't enough. I still can't figure out why it won't spring into 3-4 neutral, anyone have an idea about this?
pjsparts
Oct 29, 2025 06:39 PM
tonys91rs
Oct 10, 2015 03:31 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
