3rd gen wheels on 4th gen rear
Old Apr 18, 2004 | 08:40 PM
matt formula's Avatar
Car: 1990 firebird formula
Engine: V8 305 TBI
Transmission: TH700R4
i'm planning to swap my 3rd gen rear out for a 4th gen rear because my 3rd gen rear is crapping out, so my question is can i just put my 3rd gen wheels on the 4th gen rear without a problem or would i need wheel spacers?
Old Apr 18, 2004 | 09:45 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
yes, but their gonna stick out about 1 1/2 inches outside the fender wall.
Old Apr 18, 2004 | 10:24 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You only need spacers when going with 4th gen wheels on a 3rd gen rear. 3rd gen wheels on a 4th gen rear stick out like pasky described.
Old Apr 18, 2004 | 11:46 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
check the classifieds. there's a guy selling the rears and wheels, too.
Old Apr 19, 2004 | 07:37 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if your panhard bar is centered on your car, the tires come right TO the lip.. not beyond, but to it.
if the bar is off at all, you may have to roll a lip on one side or the other...
Old Apr 19, 2004 | 01:13 PM
Car: 1982 Trans Am
Engine: 383 chevy
he's right, except that when i put my my wheels on, the tires never really came close to scrubbing. they just stick out. it's an appearance thing, not fitment. although, i would say it's a good time to think about some custom wheels. get em cut for a 3rd gen front offset, and a 4th gen rear offset. you'll wind up with like a 0mm offset rear, and like a -37mm in the front, but I'm not positive on those measurements. (no pun intended) the cool thing is, you can go significantly wider with your rears.... 305's, anyone??
Old Apr 19, 2004 | 01:16 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
305s? HA!
you can fit 315s back there.
a friend of mine just put 17x11 rims on his 99 camaro... next time he pulls one off, im going to test fit it on mine... :lala:
Old Apr 19, 2004 | 02:01 PM
Car: 1982 Trans Am
Engine: 383 chevy
I thought you could... but I KNEW you could put 305's on. I'd like to see if it's possible to stuff 345's on the back.... damn that'd be huge, though.
Old Apr 19, 2004 | 02:08 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
nope.
at that point, even with a flared and rolled fender, you would have to SERIOUSLY modify the inner fenderwell.
Old Apr 19, 2004 | 07:32 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
so if i do a swap like htis, whats the biggest tire i can put on the 4th gen rear on a third gen chasis, 315 maybe....on a 17 inch by 10 rims..or 11.....
Old Apr 20, 2004 | 08:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
same size as the biggest you can fit with a 3rdgen wheel.
the size of the wheel well isnt changing.. only the offeset needed to keep the tire centered.
largest that can be wedged in there with only minor tweeking is a 315 series tire.... that would be on a 11" wide rim.
Old Apr 20, 2004 | 09:23 AM
Car: 1982 Trans Am
Engine: 383 chevy
sorta. if you don't care about centering, I honestly think you could go bigger, provided you're using low profile tires. a 17x11 or 17x12 would be the answer.
Old Apr 20, 2004 | 09:24 AM
Car: 1982 Trans Am
Engine: 383 chevy
I wyould say a 315/40/17 would be the biggest you need anyway. much bigger, and you're talking drag slick territory.
Old Apr 20, 2004 | 09:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
that fits in the wheel well with minor work.. mostly you just tap one bump on the inner fenderwall, and/or possibly roll the lip. depending on your exact offset.
Old Apr 20, 2004 | 11:18 AM
Car: 1982 Trans Am
Engine: 383 chevy
so it's not much of a problem.... good to know. I'm going with some WS6 wheels, or a custom set (haven't found what i like yet). who makes the best adapters for the front? transdapt seems to be cheap quality, but skulte looks like he has good stuff. what about f-body motorsports?
Old Apr 20, 2004 | 06:57 PM
Charged350's Avatar
Car: 87 IROC Z28
so 11 inch rim, i can do the wheelwell easy, tahts not a problem, i work at a body shop, but what rim comes in 11 inhes wide that fits a 4th gen rear, Zr1's or what...
Old Apr 21, 2004 | 08:25 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
factory? i only know of ZR1s... other then that, you're looking at aftermarket rims. and ofcourse aftermarket means any offset you need.
theres a bunch of used 4thgen aftermarket rims out there if you look too..
Old Apr 21, 2004 | 09:04 AM
Car: 1982 Trans Am
Engine: 383 chevy
do they have ZR1's or even good kockoffs that fit 3rd gens?
Old Apr 21, 2004 | 09:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
sure. you can use bolt on spacers to make up for any diffs. so you can run real ZR1s, or knockoffs... they make some in 3rdgen offset, but they're really narrow... kinda stupid really, the whole point of ZR1s was that they are wide.....
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
