gear swap help!
Car: 91 Camaro RS
Engine: L03 chip, airfilter,dual exhaust..m
Transmission: 5-spd
gear swap help!
I can pick up a set of 3.73's from a buddy for $75, to put in my 91 RS, L03, 5sd. The gears are from his 88-89 10 bolt 1/2 ton truck Will they fit and if so what other parts do I need?
THANKS,
Mark
THANKS,
Mark
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
its doubtful that they will fit. if im thinking correctly the trucks had 8.5" 10 bolts and we have 7.5 ". if thats correct ur gonna need to look for a new set of gears.....
not 100% sure but i think the 1/2 ton truck is the same 7.5/7.62 ten bolts as the f bodys. if they are the same then they'd fit if it's the 8.5 then they wouldn't. my truck has the 14 bolt dana rear so i'm a bit in the dark.
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
its the 8.5" rear. i helped my friend swap out his busted 8.5" 3.42's for a 14-bolt 4.10 set up. its deff. a 8.5". the S-10 is the ones that have the 7.5" 10-bolt
ambainb
Apr 25, 2016 09:21 PM
