Problem from a stop in OD
Old Apr 24, 2004 | 04:00 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Earlier this week I ran into a problem when running in OD. I hit traffic on the parkway, and came to a complete stop. When I gave it gas to get going from a stop, it would stumble badly.
Thinking it was a freak accident, I tried again the next time I had to stop and the same thing happens.
Now I shift into D and this does not happen. Same thing with the shifter in 1st. Try a couple of times, no problem.
Again I try OD and it occurs again.
The 4L60 is original (50K), and has not been rebuilt.
TIA for any help.
Old Apr 24, 2004 | 08:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the wiring for the torque converter clutch solenoid. When was the last time you changed the filter in the transmission?
Old Apr 24, 2004 | 09:10 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
First thing I had done on the car, either late July/early August (last owner was a woman who drove it for the cool factor so I know it wasn't done).
Thanks. I'll get to checking it out the wiring Tuesday when I'm off.
Old Aug 23, 2004 | 10:34 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Wow, its been a while, but the weather has really sucked when I'm off and no garage to work in.
I didn't see anything wrong with the wiring from what I could see.
Can I disconnect the lead as a troublehsooting tactic? If I disconnect the solenoid, what should happen: will the problem stop, or will it depend on the last state of the solenoid?
Old Aug 23, 2004 | 11:22 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You can disconnect the connecter to troubleshoot. The solenoid should return to its rest state. It may not do it imediatly but if your problem is with the tcc it should eventually go away with the connector disconectted.
Old Aug 25, 2004 | 07:22 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Ok, tried it, but no change.
Its happening still, just not every time. I also noticed that one time I stopped and the car bucked, and after it was fine for a few stops.
Also, now when I shift into OD form park, with my foot on the brake, the car will buck a couple of times, with kind of a loud ticking from underneath coinciding with the movement.
Old Aug 25, 2004 | 08:58 PM
chris718's Avatar
we are located in astoria.feel free to stop by for a free road test.718 784 4256
Ghettobird52
Jul 5, 2024 11:18 PM
toones
Jan 6, 2016 06:00 PM
zeitghaist
Aug 18, 2015 07:33 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
