Someone please help.....9bolt problems??
Old Apr 25, 2004 | 11:23 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Ok I am 100% sure now that my stock 2.77 series 2 9 bolt did not have a pinion shim behind the head. Now I am moving to a series 3 carries and 3.91:1 gears. Do I just press the new bearing on the new pinion without a shim since the old on didnt have one eighter? The use making compound and check the pattern?
Old Apr 26, 2004 | 04:18 AM
ede's Avatar
ede
you should meaasure and set the pinion depth to the gear makers spec. it's differant for each gear set, or could be differant, that's why a shim is used. hone your old pinion bearing out so you can slip it on and off without needing a press each time you change shims.
Old Apr 26, 2004 | 10:45 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
yea I dont have this pinion depth spec since I bought the gears from diffsolutions
Old Apr 26, 2004 | 11:42 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Nine times out of ten if you mark each shim and spacer from the gearset you are replacing and put them back in the exact same order when you install the new gears it works out okay. Make sure the pattern is good as this is the most important aspect of the swap. Next make sure the backlash is okay... not too tight and not too loose. Here is some helpful specs https://www.thirdgen.org/newdesign/t...tservice.shtml
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
