Borg Warner axle removal?
Car: 1988 Trans Am GTA
Engine: LB9 (305)
hi im wondering how to get the axles out of a borg warner rear end
b/c everything is sealed there is no lock bolt or c clip that i can see. do i have to remove the ring gear to get at it? well any help would be appreciated thanks
b/c everything is sealed there is no lock bolt or c clip that i can see. do i have to remove the ring gear to get at it? well any help would be appreciated thanks Moderator
Car: check
Engine: check
Transmission: check
I believe that there are four bolts at the brake backing area. IOW there is a hub on the flange end of the axle that is bolted to the tube. The hub retains the axle & bearing.
RBob.
RBob.
Engine: LB9 (305)
i tryed just pulling them out and its held in by something it is a 10 bolt not posi as well but i guess i'll go back out there and try to figure somethin out thanks for the imput
Car: 83 Z28
Engine: 400sb
you have to pull the bolt out that holds the pin remove the pin then push the axle in and remove the C clip off the end of the axle
then slide the axle out
Engine: LB9 (305)
thanks everybody i got it out nothing a little brute force and anger wont fix i just needed a biger hammer the bearing was seized in there
dbrochard
Oct 3, 2015 12:43 PM
rudolphschenker
Sep 4, 2015 02:41 AM
