Question about positrack
Old May 5, 2004 | 02:18 PM
Mechanix's Avatar
Car: 1985 Camaro Berlinetta
Engine: 305 sm block chevy
I don't know where to post this but would someone explain to me why with a positrack rear end if you spin one tire the other goes in the opposite direction?
Old May 5, 2004 | 02:29 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
actually the myth for posi-traction is if you spin one tire the other will spin the same way.
posi-traction is just GMs name for a limited slip.
here: http://auto.howstuffworks.com/differential.htm
Old May 5, 2004 | 04:23 PM
Bandit5's Avatar
That is with a non-posi rear end.
If you don't have a posi rear end (open differential) when you have the car in the air (jacked up) and the wheels are off the ground, when you spin one wheel, the other will go in the opposite direction.
Old May 6, 2004 | 10:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
yet.... the 02 trans am i was swapping rears on 2 weekends ago did the same thing.. they spun the oppisiate way.
but.... it has a posi.
the 4thgen SS i was messing with the same weekend did the same thing... they spun the opposite direction.
but..... it has a posi.
the only SURE way to know is to look.
and you probly need to change the gear oil anyway, so just pull it and look.
the spinning the tire method is pure bullsh!t. only SOME limited slip diffs spin the same way, and of thoes, some spin the oppsite when they're worn.
Old May 6, 2004 | 10:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The newer ones (LS1 cars) don't have clutches; they accomplish the same end result in a different way. Therefore the "test" doesn't work on them.
You can't go by all of those "tests" you hear about; the only sure way to know what you've got, is to take off the cover and look.
Old May 6, 2004 | 10:49 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
bingo.
athough my car doesnt pass the test either..... then again, i dont have a stock posi unit in mine.. its also clutchless.
Old May 6, 2004 | 03:00 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
My 9" Trac loc will spin the wheels in opposite directions, yet it will lay two equal length strips of rubber on the ground. Point is there are many different types/designs of limited slip differentials out there. They all accomplish the same thing by different methods.
Old May 7, 2004 | 12:15 PM
Mechanix's Avatar
While all that info's great I kinda meant how do both whells spin the same direction while in drive but when the back of the car is in the air if you spin one wheel the other goes in the opposite direction?
Old May 7, 2004 | 12:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
from the link i posted:
http://auto.howstuffworks.com/differential3.htm
look at the animation. if you think about it carefully, you'll be able to visulize how everything is moving.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
