Is my car Posi?????????
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
im wondering if my car is posi, its a 89 trans am with a 305 and 700r4 trans, i did a couple burnouts and 3 times it was two wheels and the others were one.
Car: 2002 Formula Firebird
Transmission: 4l60e
So was it posi or not? Right now I have a non-posi rear but it spins both while powerbreaking.
Next week I will have my 3.73s and stuff in. I'm excited.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
sounds like a posi that is wearing out.
G80
AXLE POSITRACTION, LIMITED SLIP, 28 spline
look for that rpo code, G80
G80
Car: 4
Engine: 6
Transmission: 5
What ede said. All of that crap about 2 tires is just that, crap.
I'd almost be willing to bet money the car didn't come with it; but who knows what it's got now, without pulling the cover.
Originally posted by Borsty
lol thats a sweet smiley.
anyways its stock so it would be watever it came with.
whats a RPO code?
lol thats a sweet smiley.anyways its stock so it would be watever it came with.
whats a RPO code?
rpo is production order or what the car was built with
Car: 4
Engine: 6
Transmission: 5
That's what they all say; except when they tell you it's a 350, or "from a Vette", or "police interceptor". All that means is, he hadn't changed anything he was willing to admit to. Who knows what some other PO might have done to it, or what it might have needed under warranty, or whatever.
Takw off the cover and look. It's the only way to know for sure.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you put your hand on the differential cover after you drive around for a bit and it feels warm, thats posi-energy emminating from the posi unit.. If its cold, then its an open rear..
Well, kidding aside, pull the cover and look because you probably need to change the fluid that is back there anyway, and you could kill two birds with one stone...
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
i heard that if you turn one wheel one way and if the other rotates the other then you have a posi...is that right?
Car: 4
Engine: 6
Transmission: 5
No, that is exactly wrong. That's EXACTLY what a posi is intended to fix.
The most common kinds, like the one in my pic, uses clutches to connect the axles to the carrier, such that in order to make the axle rotate at any speed other than the carrier's, enough torque has to be applied to overcome the clutch. That's typically in the 50-90 ft-lbs neighborhood for various models of car rear ends, for each axle.
The thing about the wheels spinning in opposite directions is what happens when you take a non-posi rear, and hold the carrier still. Under those conditions, rotating one wheel will make the other rotate at the same speed but in the opposite direction; and it takes virtually zero torque to do so.
From: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
You could crawl under the rear and if you see a tag on the differential under one of the bolts then its posi, or if you could jack the rear off the ground safely and put it in drive and if both wheels spin then its posi if only one wheel spins its an open rear
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
So what do you all call it. Posi or limited slip. The correct term is limited slip is it not?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Is my car Posi?????????
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
