Electronic differences between 200r4 and 700r4
Old May 13, 2004 | 05:10 AM
S10Wildside's Avatar
What are the electronic differences between the 200r4 and 700r4? Are there three wires going to the 200r4? Is the connector compatable? Does the ECM control the TCC functionality just like it would the 700r4?
Old May 13, 2004 | 05:17 AM
ede's Avatar
ede
yeah the ecm controls the 200 the same as the 700, not at all
Old May 13, 2004 | 06:18 AM
The ECM does controll the TCC functionality in the 700r4. There are three wires that go to the 700r4. Two from the ECM and one to the brake switch. The speed where TCC lockup occurs can be changed in the prom.
The ECM does not control the shift points in the 700r4. I don't want this post to focus on the ECM control of the transmission...which it does not do.
Does the 200r4 have TCC functionality? I have never worked with a 200r4 and never seen a 200r4 to know if it has electronics going to it.
Old May 13, 2004 | 08:10 AM
ede's Avatar
ede
ok i thought you were after how the ecm shifts the trans and nothing more. it's hard to gauge someones knowledge or lack of knowledge on a subject and as brief as your question was lead me to belive you only was concerned about shifting.
Old May 13, 2004 | 12:18 PM
Not a problem.
Hopefully someone has a good idea.
Old May 13, 2004 | 12:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes it does, and it uses the same 4 pin connector as the 700R4. The wiring of internal switches may or may not be slightly different.
Old May 13, 2004 | 01:36 PM
Awesome, that answers part of my question. Anyone know if the wiring is different?
Old May 13, 2004 | 03:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't have wiring diagrams for the 200-4R, but it would depend on what car it came out of, what engine it had, and possibly a few other things.
Old May 13, 2004 | 05:38 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Some 700r4's, like the one in my 84 TA are locked up by a vacuum switch, not the ecm, but they still use the same 4 pin connector.
Old May 13, 2004 | 08:42 PM
Thanks guys.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
