Rebuilt tranny doesnt shift
Old May 19, 2004 | 08:11 AM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
What would cause an rebuilt 86 700r4 with a transgo shift kit not to shift from 4th to 2nd?
Old May 19, 2004 | 08:52 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
TV cable out of adjustment possibly.
Old Jun 2, 2004 | 08:39 PM
Guest
Guest
Posts: n/a
Re: Rebuilt tranny doesnt shift
sounds like the pin for the band fell out of palce when you installed it or the servo is not installed right.... the band in the 700R4 is called by many the 2-4 band thats what holds the drum when you get 2nd and 4th gear
Old Jun 3, 2004 | 01:56 PM
Pro Built Automatics's Avatar
If you are trying to make a 4-2 downshift and it doesn't happen, make sure the TV cable is tight to very near tight at WOT. If you cannot get it to do the 4-2 downshift, and it shifts at the right rpm at WOT, then it might not be possible to do this in your case.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
