TV cable will not adjust for ****...WTF!!!
Old May 24, 2004 | 07:31 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
ok, so its a carb now, i fabbed up a new throttle baraket and a kickdown kable braket, but it wond adjust when i press the small metal part down and WPT it, so im moving the braket back a little by little its shifting better, but sumtimes it still wont kick down...wtf is this all about.,...
Old May 24, 2004 | 07:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you did your swap out, did you change the TV cable also? BTW, what is WPT? Also what are the procedures that you are using to adjust the TV cable besides pushing in the metal button?
Old May 24, 2004 | 09:58 PM
Charged350's Avatar
Car: 87 IROC Z28
no, i didnt even touch the cable, so there is no way it could have disconnected inside the tranny,
and my screen reads wtf..i donno about yours
anyways, i push the metal part down, open her wide throttle let go of teh tab, and let go of the throttle no clicking no nothing, wtf iis goin on...
Old May 24, 2004 | 10:19 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: TV cable will not adjust for ****...WTF!!!
Old May 24, 2004 | 10:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It could be that there is a little more involved in adjusting the TV cable than pushing the metal button and going wide open throttle. You must first push the metal button in, pull the black cable towards the firewall and release the metal button, and then go wide open throttle and listen to it ratchet.
Old May 25, 2004 | 08:49 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
One more time copy and paste....
GM 700R4 Throttle Valve Cable Adjustment
1. Remove air cleaner on vehicles with carb or TBI.
2. Depress lock tab down on TV cable and push cable all the way forward towards carb or injector.
3. Have someone sit in vehicle and depress gas pedal to the floor so it's at WOT (Wide Open Throttle). Hold it there for steps 4 and 5.
4. Now check to make sure the carb arm is bottomed out or has no more movement. If not, use a pair of Channel Locks to bend TV cable bracket until carb or injector arm no longer rotates.
5. Next, depress lock tap down and pull TV cable back (Pull HARD!) towards firewall or away from carb or injector until it stops and then release the tab.
6. Use a pocket knife or hacksaw blade to mark the cable in front of the snout. This is MAX TV.
7. After marking Max. TV depress lock tab and push cable forward toward carb or injector 1/8'' of an inch. Make a mark in front of snout. This is Minimum TV.
8. Set cable back to Max. TV and Road Test.
Leo's way
Start with correct TV setting: To adjust the TV Cable skip the book method and do this: Press the 'D' shaped lock button on the adjuster and loosen the cable setting (The black housing that the metal cable is in will move forward). Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the 'D' button and pull the cable casing (the black tube) back as hard as you can (putting maximum tension on the metal cable) and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable casing so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Old May 25, 2004 | 08:50 PM
Engine: 406
Double post
Old May 27, 2004 | 07:07 PM
Charged350's Avatar
Car: 87 IROC Z28
okk, now i see, thanx guys, i was ****in with it all wrong...
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
