tranny compatibility
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
im pretty sure the answer is yes but will an 86 V8 700-R4 go into a 90 350 tpi engine with no problems?
Car: 1990 Camaro
Engine: 355ci
i just realized that the 86's have a mech speedo and the 90's have an electric, i have the tranny from my 90 but the gears are all torn to hell and im getting the 86 one for free is it possible to change the tail shaft out so i can use my electric speedo
Car: `86 SS / `87 SS
If you were a friend of mine...
A close personal friend I could tell anything...
I'd slap you upside the head with an audible <:::POP:::> so you'd quit your blubbering.
Now remove the tailhousing, put the 90 speedo drive gear on the 86 output (if different tooth count) and install the 90 VSS crap. Expect the earlier (pre-88) trans. to not live as long as an 88+ model.
swap swap swap
swap swap swap
Car: 1990 Camaro
Engine: 355ci
thanks a good slap upside the head is exactly what i needed
and thats exactly what i needed to know. Ya this tranny already has 170 k on it
im hoping to get 5-6000 km out of it and ill be happy Supreme Member
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
im hoping to get 5-6000 km out of it and ill be happy Thread
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
