Trans. Not pulling in Drive
Old May 26, 2004 | 04:46 PM
Camin89Camaro's Avatar
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
I have a 700r4 trans and when you put it in drive or 1 which ever it pulls fine it has been sliping a bit between gears but now as soon as it shifts out of 2 in to drive it will not pull at all same in overdrive the car has not been drove in about a week and a half and did not slip that i noticed and def. not like it is now, time for a rebuild? any other suggestions
Thanks,
Chris
Old May 30, 2004 | 06:21 PM
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
nobody? this is my daily driver and i dont really have the money to rebuild it right now
Old Jun 2, 2004 | 08:25 PM
Guest
Guest
Posts: n/a
ptu the shifter doen in 1st gear nto drive.... if it shifts fine when you shift it into 2nd by hand you ahve a bad cluth pack or a band is going... when you drop it into 1st gear you have the "Over run protection" clutches on and they why it won't slip... thats oen way to test it.... its also a way to "Limp" home when you fry your trans at the strip..... lol believe me been there done that
Old Jun 3, 2004 | 02:05 PM
Pro Built Automatics's Avatar
If you have 1st & 2nd only, then you have lost the 3-4 clutch pack (very common), time for a rebuild.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
maroe624
Apr 16, 2017 08:29 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
