How Much Hp Will This 10 Bolt Hold
I HAVE AN 89 TA WITH A 434 SBC,CARBED MOTOR,THE REAR HAS MOSER 28 SPLINE AXLES AND EATON POSI UNIT AND RICHMOND 4.10 GEARS,T-56 TRANS.THE CAR LAST WEEK AT THE DRAG STRIP RAN 7.2 AT 99 MPH IN THE 1/8 MILE,THAT WAS WITH A 1.90 60FT WITH NITTO DRAGS.I WAS SPINNING THE TIRES HALF WAY DOWN THE STRIP.I WANT TO RUN SLICKS TO SEE WHAT THE CAR CAN RUN WITHOUT KILLING MYSELF DO YOU THINK THIS REAR WILL HOLD UP
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Manuals will blow it up a lot faster than a auto. Its the tourque and sudden traction that kills these, I think horsepower is a minor issue.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ive been told the same thing before by a local speed shop as well thats why i went with 3.73s
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i dunno what yall are putting in your morning coffee, but the numerically higher gear ratios will put less stress then the gearset lower...for example, lower gears 2.77 3.23's require more torque to get them spinning so they will absorb more stress....while the 4.10s require a whole lot less torque to get them spinning so they take in less stress
same car, same tranny, same rear, tires, motor everything the same except for the gears, the guy with the lower numerically lower gears will break before the guy with 4.10's
its not because of the ratio, read my post again, it has something to do with the way the ring gear mounts to the carrier.. someone will chime in soon and give you exact details
uh, posi units arent made for anything except the designated carrier they go in
there are two kinds of carriers, 2 and 3 series, one is for gears 3.08 and lower and the other is for higher
I believe the 2 series 4.10 gears are the weakest from what I have heard
but, im surprised you didnt know that a posi unit doesnt bolt to the ring gear since you sound like you know so much
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Usually the steeper the rear gear the weaker it is. A 4.10 will not be as strong as 3.73 in most cases. To get the higher rear gear the teeth on the ring gear and pinion have to be smaller because there are more teeth. The smaller teeth cannot take as much torque as the larger teeth of a lower gear set.
Also the 10 bolts weakness is that the case deflects with torque and the 4.10 gears will put more torque on the housing then 3.73 gears causing the case to deflect and break.
i never said the ring gear bolted to the posi unit. you just twisted what i said around,,,yeah you would think that if anything, people that go 3,73 and higher are going to race the car, and that they are going to make them weaker for the people that race,im 35 years old man and been going this for a long time.and i think there is nothing thats says 4.10 gears are weaker,all i want is input,if the 10 bolt would hold up to slickes with this setup.now with that said i dont givea f**k about it,what ever. 4.10 gears are not weaker than 3.73.....now the 7.5 ring gear yeah thats a weak ring gear,but the 4.10 gears will last as long or not longer than the 3.73s
New2Chevy
Sep 28, 2015 12:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
