can't figure it out
Old Jun 2, 2004 | 09:30 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
can't figure it out
when i drive my engine speed goes up and down, anyone know anything
Old Jun 2, 2004 | 09:56 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Hold your brake pedal down slightly while you're going 55mph.
If the rpm goes up slightly, and doesn't surge up and down any longer, then your TCC may have been locking and unlocking. This can be due to the ECM getting poor signal from the TPS, VSS, CTS...
Old Jun 2, 2004 | 10:01 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i'll try it in the morning but the only ones i know what mean are ECC and TPS and ECM what are the others, and what if it still does it?
Old Jun 2, 2004 | 10:02 PM
jmd's Avatar
jmd
coolant temperature sensor
torque converter clutch
throttle position sensor
let us know.
Old Jun 3, 2004 | 01:01 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
ok so i was driving down the freeway and did what you said, while i was doing 55 i let off the gas and pressed the brake slightly, no wierd speed, when i went back to the gas it started doing it again, tried this both in d and od. even did the same thing while pressing the gas and the brake same results, so wassup now any suggestions?
Old Jun 5, 2004 | 08:36 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
:oke:: :oke:: any comments, also i forgot to mention that i also smelled something similar to a clutch burning when i did this
Old Jun 5, 2004 | 09:34 AM
jmd's Avatar
jmd
Unplug the VSS plug at the tranny (4 wire square)
If it stops, then you know that the TCC unlocking & locking is your problem.
As to figuring out whether it's VSS or temp or whatever bad value to the ECM or wiring that's causing the problem, that's another story.
Old Jun 5, 2004 | 11:44 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
one question before i do, what exactly is the vss, been searching and it appears that it is my spedometer cable? is this correct? am i cutting anything else off when i do this. not questioning you i just like to know what i'm getting myself into
Old Jun 5, 2004 | 10:52 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
and where is the hookup on the trans, got a pic or maybe a side dir?
Old Jun 6, 2004 | 03:26 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
so i unhooked that 4-wire plug, one question before i drive to work tomorrow hopefully someone will respond, can i do damage to anypart of my car with the plug unhooked? and i thought the vss also controlled my spedometer?
Old Jun 7, 2004 | 12:21 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
Good news, i unhooked the vss from the tranny, no more problems. Just a few minutes ago i read that leaving it unhooked could cause it to burn out a 4th. Now the question is which is easiest way to check the system? Or should i just start replacing parts in order of easiest to hardest?
Old Jun 7, 2004 | 01:17 AM
jmd's Avatar
jmd
put a volts-meter on your TPS and see if it operates smoothly voltage-wise, and also maintains a consistent reading when held steady.
actually easier would be to plug a scanner in and check TPS and also the temp reading. And VSS reading.
Your VSS is in the tranny tailhousing; signal is fed to a DRAC which feeds the ECM, and then the speedo/cruise.
So grab a scanner.
Old Jun 7, 2004 | 09:31 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
cool i think autozone still does that for free
Old Jun 8, 2004 | 06:42 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
question, is what i read correct, can i lose my trans with the vss disconnected?
Old Jun 9, 2004 | 08:51 PM
jmd's Avatar
jmd
it adds heat w/ out lockup; 700s don't like that. Unhook it for diagnosis only; once you figure it's the solenoid, go ahead and change those parts ASAP.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
