Speedometer Gear Change
Old Jun 3, 2004 | 08:20 AM
Mister421's Avatar
I have searched for this but can't seem to find what I'm looking for. I am looking for some kind of details on how to change out the speedometer gears on a 91 Formula with a T-5. Is the removal of the tailshaft and shifter needed? Once this is removed how difficult is it to change the gear? How does the gear come out from the trans? We removed the sensor with the small gear from the car but can't seem to figure out how you pull the gear from it. Just looking for some help so we don't break anything. Any directions would be great. We have the SLP speedometer gears. Thanks in advance.
Old Jun 3, 2004 | 09:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The small gear on the sensor just pulls off and you stick the other one on.
If you have to change out the one inside the trans, that's on the mainshaft, you'll need to pull the trans out and take the extension housing off. I don't think it can be done in the car; but even if it can, by the time you get to the point where you could change the gear, you've already done about 95% of the work of pulling the trans anyway(all but the last 4 bolts) and you might as well go ahead and pull it out and work on it on the bench where it's easy.
Old Jun 3, 2004 | 10:10 AM
Mister421's Avatar
Thanks for the reply. When you say the small gear pulls off does that mean it pulls off the shaft or does the entire shaft pull out? The new small gear is mounted on a shaft like the current one is.
Old Jun 3, 2004 | 10:13 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
with the small gear, you pull the VSS or cable drive from the trans.
it will have the gear on it.
it just pulls off of it.
slip new gear on....
and put it back in the trans.
Old Jun 3, 2004 | 10:28 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
should have searched....anyway here this might help.
https://www.thirdgen.org/techbb2/sho...ht=%2Aspeed%2A
BTW: I didn't know SLP made speedo gears for T-5's I thought they were just for automatics.
Old Jun 3, 2004 | 10:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A cable speedo driven gear has the little gear with 20 or so teeth, and it has a shaft that's about 3/8" diameter and 2" long.
A VSS driven gear is just the round part with the teeth, has a little D-shaped hole in the middle; the old one pulls off the VSS and the new one slips on.
A pic of anything you can take a pic of, along with a description of exactly what you have and what you're trying to do, would be very helpful.
SLP doesn't "make" speedo gears. They just fence them for GM.
jklein337
Sep 19, 2018 06:23 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
jbd1969
Aug 17, 2015 07:06 PM
