Screwed up t-5
Old Jun 16, 2004 | 01:05 PM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
Screwed up t-5
Well i was coming home from work last night and i was pouring rain. Well to my suprise my street was flooded and before i could do anything my car half deep in water. well i think i might have filled the tranny with water but i am not sure yet. If i did fill it with water will it screw anything up? Wont have anymoney till friday to put gear oil in it. if i only drive where i need to go will i break anything i the tranny? thanks for the help
Old Jun 16, 2004 | 01:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If water didn't come up over the car floor, it didn't get into the trans.
It's probably OK.
But if it DOES have water in it, it will trash it, FAST. Water doesn't lube worth a flip.
Old Jun 16, 2004 | 09:02 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Here's one for you. Last winter I was trying to get my jeep running. It's an old beater CJ5 that we basically use to tool around the woods. I got it started, but the shifter was like welded in gear. I couldn't move the stick, despite countless attempts. Finally I broke down and pulled the cover off the trans. The case was totally filled with ice. We heated it up with a propane torch and dumped a pot of boiling water into it and it melted all the ice. When I drained it there was about three drops of oil in it. I know it's been like that since I've owned it, and that's been four years! I topped it off with fresh gear oil, re-sealed the top and off I went. The annoying gear noise is a lot quieter now too. It doesn't seem to be damaged in the least. When it does get used I really flog the snot out of it. I'm talking 5,500 RPM powershifts while hill climbing in low range (which is now 3.15:1 on top of my first gear ratio and 3.54 rear gears).
I think you're fine, even if you have to limp it like that for awhile. It would be hard for water to get into it anyway, unless you were driving it through a stream with water up to the bottom of you seats...
Old Jun 18, 2004 | 09:50 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
should be ok if you get it all out. but i see a very small chance water got in it like the others have said... also
check to be sure it doesnt take atf some do.
Old Jun 19, 2004 | 03:27 PM
well the water was up to about the middle of my doors. and a little bit came in through hole in my floor. i drained it today and i got about a gallon and a quart of oil and water out of it. i havnt driven it yet but i think it will be ok.
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
