need new tranny?
Old Jun 19, 2004 | 04:13 PM
tony.ryno's Avatar
need new tranny?
Well, my transmission started slipping in third and fourth gear yesterday at about anything more than 10% throttle and today to get it to change gears from 1st to 2nd and then from 2nd to third I have to put it in neutral and then back in to drive otherwise it will shift at around 4k while I am giving it only little throttle. I drive a 92 Camaro with a 3.1 and automatic. Any help here would be greatly appreciated. I also read in another forum that the ECM could not be getting a good sensor reading from th tranny and not telling it to shift but I think that was for a V8 tranny. I also installed a new tranny filter and gasket, new fluid and some trannny additive but then it started the whole not wanting to shift thing. Thanks in advance.
Old Jun 20, 2004 | 07:05 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Is your TV cable adjusted properly?
Old Jun 20, 2004 | 11:25 PM
tony.ryno's Avatar
No I hadn't checked that yet because it seemed as though all the other posts had adifferent thing happening to them with that problem but I will check it tommorow and see where it gets me.
Old Jun 21, 2004 | 02:31 PM
tony.ryno's Avatar
checked that today, it was loose but after I fixed it I drove it for maybe a 1/4 mile and still the same problem, is it the governor gear and if it is where is the best place to go to read/see about replacing it.
Old Jun 26, 2004 | 08:49 PM
tony.ryno's Avatar
well, checked the governor gear today but it was near new looking and everything looked to be in good working order so now i have no clue as to what could be causing this, anyone got a clue?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
